Subject: R3-3 of ADSpinnaker
From: Mark L Rivers via Tech-talk <[email protected]>
Date: Sun, 14 Nov 2021 23:45:30 +0000
Folks,
ADSpinnaker R3-3 is available.  This is from the release notes:
* Fixed a problem reading Integer GenICam feature values, and their min and max.
  The values were being cast from Int64 to Int32.  This was not correct.
  This was a problem, for example, with values whose maximum was 2^32-1, because the maximum was read as -1.
  This resulted in not being able to set the value, since the allowed maximum was less than the allowed minimum.
https://github.com/areaDetector/ADSpinnaker
Prev: Fwd: StreamDevice Format Converters Zimoch Dirk (PSI) via Tech-talk
Next: Re: StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Prev: Re: StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Next: AppImages for EPICS base Zhang, Tong via Tech-talk
