Subject: Re: StreamDevice Format Converters
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Mon, 15 Nov 2021 09:25:11 +0100
Thank you for your help.
I was able to get the correct result using ESLO. I miss understood the "=" operator in StreamDevices.
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 12.11.2021 17:25, Eric Norum je napisao(la):
Could you read it into an ai record RVAL using %d and then use ESLO to
scale the result?
On Nov 12, 2021, at 2:18 AM, Donny Domagoj Cosic via Tech-talk
<[email protected]> wrote:
I receive a string from a device containing the current draw as a 6
character number. ie. for 2.45 A, the string would be 000245. Using
the format converter %6f in the proto file, I am able to read the
value into a ai record as 245. However when I try to convert the
input string using %=6.2f, I always read in 0 as the current.
Am I understanding the = operator properly? How can I convert the
string 000245 input into 2.45 in the ai record?
Thank you in advance,
Donny Domagoj Cosic
T: +385 1 4561 041 | @: [email protected] | www.irb.hr [1]
Eric Norum
[email protected]
Links:
[1] http://www.irb.hr
StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Prev: R3-3 of ADSpinnaker Mark L Rivers via Tech-talk
Next: Re: Access motor controller target positions of other axes in asynMotorAxis::move Laurenz Rettig via Tech-talk
Prev: Fwd: StreamDevice Format Converters Zimoch Dirk (PSI) via Tech-talk
Next: R3-3 of ADSpinnaker Mark L Rivers via Tech-talk
