Subject: Fwd: StreamDevice Format Converters
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Sun, 14 Nov 2021 13:15:44 +0000
I had accidentally dent this to the wrong address…
Von: "Zimoch Dirk (PSI)" <[email protected]>
Datum: 12. November 2021 um 11:29:00 MEZ
An: Donny Domagoj Cosic <[email protected]>
Kopie: Tech-talk <[email protected]>
Betreff: AW: StreamDevice Format Converters
You get the number as a 0 padded decimal integer. Thus use %d. The value 245 will end up un RVAL. Let the ai convert the value for you to 2.45 by setting ESLO to 0.01. Set LINR to LINEAR or SLOPE.
The %= format is meant to check if a readback contains the expected value. It can appear in an 'in' command but behaves like an output format. What it does is: Did I read the same string I would get if I printed the current value with this format? It does not set anything in the record but may cause a parse error if the string does not match the expectation. Useful in output records when the device sends back the written value and you want to check if the device understood the correct thing.
-----Ursprüngliche Nachricht-----
Von: Tech-talk <[email protected]> Im Auftrag von
Donny Domagoj Cosic via Tech-talk
Gesendet: Freitag, 12. November 2021 11:18
An: Ralph Lange via Tech-talk <[email protected]>
Betreff: StreamDevice Format Converters
I receive a string from a device containing the current draw as a 6
character number. ie. for 2.45 A, the string would be 000245. Using the
format converter %6f in the proto file, I am able to read the value into
a ai record as 245. However when I try to convert the input string using
%=6.2f, I always read in 0 as the current.
Am I understanding the = operator properly? How can I convert the string
000245 input into 2.45 in the ai record?
Thank you in advance,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Prev: Re: StreamDevice Format Converters Ralph Lange via Tech-talk
Next: R3-3 of ADSpinnaker Mark L Rivers via Tech-talk
Next: Re: StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
