Hello Torsten and Mark,
thank you for your prompt replies.
In fact I had problems with two motors where UEIP was set to 1(Yes). Has always been like this ;-)
According to the documentation, this should also work if MSTA indicates that no encoder is present.:
Switch: nonzero value tells the record to read the encoder (if the hardware indicates an encoder is present) and to ignore the value read back from the hardware's step-count register.
The state of the UEIP, together with the MSTA encoder indicator, determine:
• if the RRBV is set to either the feedback (REP) or the command (RMP) position.
• whether absolute or relative position commands are used.
epics@felgate:~$ caget FHIFEL:M12PH.MSTA
FHIFEL:M12PH.MSTA 3
• DIRECTION: last raw direction; (0:Negative, 1:Positive)
• DONE: motion is complete.
• PLUS_LS: plus limit switch has been hit.
• HOMELS: state of the home limit switch.
• Unused
• POSITION: closed-loop position control is enabled.
• SLIP_STALL: Slip/Stall detected (eg. fatal following error)
• HOME: if at home position.
• PRESENT: encoder is present.
• PROBLEM: driver stopped polling, or hardware problem
• MOVING: non-zero velocity present.
• GAIN_SUPPORT: motor supports closed-loop position control.
• COMM_ERR: Controller communication error.
• MINUS_LS: minus limit switch has been hit.
• HOMED: the motor has been homed.
This now seems to be behaving differently.
Danke,
Heinz
> On 16. Nov 2021, at 18:15, Torsten Bögershausen <[email protected]> wrote:
> Hej Mark and Heinz,
> If I command the motor to -10 mm,
> and it runs into the limit switch at -2.970
> The we see that .VAL stays at -10 mm, (where the motor should have gone)
> and .RBV is -2.970 (where the motor is)
> So the “correlation” is lost - on purpose.
> Thats my understanding.
> HTH
> /Torsten
>> On 16 Nov 2021, at 18:09, Mark L Rivers via Tech-talk <[email protected]> wrote:
>> Hi Heinz,
>> It looks like you are using an encoder (UEIP=Yes), and your encoder readback (REP) is 0. When the motor record hits a limit switch I believe it sets the DVAL to the readback value.
>> Mark
>> From: Tech-talk <[email protected]> on behalf of Heinz Junkes via Tech-talk <[email protected]>
>> Sent: Tuesday, November 16, 2021 10:59 AM
>> To: EPICS Tech Talk <[email protected]>
>> Subject: Understanding Motor Record
>> I am having problems with Motor-Record right now.
>> I am using Epics 7 and the latest MotorRecord
>> (master: https://github.com/epics-modules/motor)
>> When I reach a Limit - Switch, then there is no
>> correlation between RMP and DVAL/VAL anymore?
>> RMP : 1361 vs. DVAL: 0 and VAL : 0 ??
>> I'm using the same hardware as I have for 10 years (Oms MAXv), only
>> now I have Epics7 with the new motor-record in use.
>> I also have the feeling that something with the conversion of the
>> EGU and the direction etc. does not fit.
>> But unfortunately can not specify yet because "somehow some is wrong”
>> Danke Heinz
>>> dbpr FHIFEL:M11PH,10
>> ACCL: 1 ACKS: NO_ALARM ACKT: YES ADEL: 0
>> ALST: 0 ASG : ASP : PTR 0x0 ATHM: 0
>> BACC: 1 BDST: 0 BKLNK: ELL 0 [0x0 .. 0x0]
>> BKPT: 00 BVEL: 4.5 CARD: 0 CBAK: PTR 0x15f9bf8
>> CDIR: 1 CNEN: Disable DCOF: 0
>> DESC: M1 Pinhole OMS_Z DHLM: 140 DIFF: 0
>> DINP: CONSTANT DIR : Pos DISA: 0 DISP: 0
>> DISS: NO_ALARM DISV: 1 DLLM: -140 DLY : 0
>> DMOV: 1 DOL : CONSTANT DPVT: PTR 0x15f9c18 DRBV: 0
>> DSET: PTR 0x462d34 DTYP: OMS MAXv DVAL: 0 EGU : mm
>> ERES: 1.171875e-04 EVNT: FLNK: CONSTANT FOF : 0
>> FOFF: Frozen FRAC: 1 HHSV: NO_ALARM HIGH: 0
>> HIHI: 0 HLM : 140 HLS : 1 HLSV: NO_ALARM
>> HOMF: 0 HOMR: 0 HOPR: 0 HSV : NO_ALARM
>> HVEL: 4.5 ICOF: 0 IGSET: 0 INIT:
>> JAR : 7.5 JOGF: 0 JOGR: 0 JVEL: 4.5
>> LCNT: 0 LDVL: 0 LLM : -140 LLS : 0
>> LLSV: NO_ALARM LOCK: NO LOLO: 0 LOPR: 0
>> LOW : 0 LRLV: 0 LRVL: 0 LSET: PTR 0x1548258
>> LSPG: Go LSV : NO_ALARM LVAL: 0 LVIO: 0
>> MDEL: 0 MIP : 0 MISS: 1
>> MLIS: ELL 148 [0x2190a58 .. 0x177254c8] MLOK: 01 54 f4 10 MLST: 0
>> MMAP: 0 MOVN: 0 MRES: 1.171875e-04 MSTA: 7
>> NAME: FHIFEL:M11PH NMAP: 0 NSEV: NO_ALARM NSTA: NO_ALARM
>> NTM : YES NTMF: 2 OFF : 0 OMSL: supervisory
>> OUT : VME_IO #C0 S2 @ PACT: 0 PCOF: 0
>> PHAS: 0 PINI: NO POST: PP : 0
>> PPN : PTR 0x0 PPNR: PTR 0x0 PREC: 3 PREM:
>> PRIO: LOW PROC: 0 PUTF: 0 RBV : 0
>> RCNT: 0 RDBD: 0.1 RDBL: CONSTANT RDES: PTR 0xcbd400
>> RDIF: 0 REP : 0 RHLS: 1 RINP: CONSTANT
>> RLLS: 0 RLNK: CONSTANT RLV : 0 RMOD: Default
>> RMP : 1361 RPRO: 0 RRBV: 0 RRES: 999.99
>> RSET: PTR 0x462f4c RSTM: NearZero RTRY: 5 RVAL: 0
>> RVEL: 0 S : 5 SBAK: 3 SBAS: 3
>> SCAN: Passive SDIS: CONSTANT SET : Use SEVR: NO_ALARM
>> SMAX: 12 SPDB: 0 SPMG: Go SPVT: PTR 0x0
>> SREV: 12800 SSET: 0 STAT: NO_ALARM STOO: CONSTANT
>> STOP: 0 STUP: OFF SUSE: 0 SYNC: 0
>> TDIR: 1 TIME: 2021-11-16 16:45:24.834573822 TPRO: 0
>> TSE : 0 TSEL: CONSTANT TWF : 0 TWR : 0
>> TWV : 1 UDF : 0 UDFS: INVALID UEIP: Yes
>> UREV: 1.5 URIP: No VAL : 0 VBAS: 4.5
>> VELO: 7.5 VERS: 7.2 VMAX: 18 VOF : 0
smime.p7s
Description: S/MIME cryptographic signature
- RE: Understanding Motor Record Mark L Rivers via Tech-talk
- Understanding Motor Record Heinz Junkes via Tech-talk
- Re: Understanding Motor Record Mark L Rivers via Tech-talk
- Re: Understanding Motor Record Torsten Bögershausen via Tech-talk
RE: Failed connection using e3-s7plc to Siemens S7-1500 Miklós Boros via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
