Hi Matt,
I placed our iocStats (with network statistics for Linux and RTEMS 4.10, detection of not connected ca links and not connected PVs used by the seq programs) which we use currently in LBNL to my github with the intention to merge it with the official version of epics_modules/iocStats
Currently you can clone it from and then change the branch to network.
It is included the test ioc testIocNetStatsApp which you can use as a reference. Examine the testIocNetStatsApp/src/Makefile to see how to link the iocstats library when the sequencer is used.
Best Regards Mirek
On Tue, Nov 16, 2021 at 8:35 AM Zimoch Dirk (PSI) via Tech-talk < [email protected]> wrote: [I have tried to send this mail already but it seems lost in cyberspace. If you you got it already, sorry for the
duplication.]
At PSI, we are not using IOCMON any more but iocStats. And yes, I have added support for disk space.
Our version is here: https://github.com/paulscherrerinstitute/iocStats
This is the template (instantiate once one per disk):
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/iocAdmin/Db/iocFsStats.template
And here are the implementations for posix, vxWorks and Windows.
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/devIocStats/os/posix/osdFileSystem.c
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/devIocStats/os/vxWorks/osdFileSystem.c
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/devIocStats/os/WIN32/osdFileSystem.c
It uses our PSI build system and several PSI internals but you may want to merge the changes with the "official"
iocStats.
Dirk
On Mon, 2021-11-15 at 17:21 -0800, Tynan Ford via Tech-talk wrote:
> There is IOCMON from PSI that contains some network statistic support for VXWorks:
> http://epics.web.psi.ch/software/iocmon/
> We at ALS are using a similar idea from this to monitor network statistics on our linux servers. A colleague worked on
> that and we can discuss that more or share the code. We don't have disk space stats but that would be interesting.
> To address the PV duplication, we ended up separating the existing iocStats database into 2 separate files. An "IOC-
> specific" stats database and a "System-specific" database. Then for each of our soft IOC servers, we have one dummy
> soft IOC that simply loads the system stats database.
> Best,
> Tynan
> On Mon, Nov 15, 2021 at 1:00 PM Pearson, Matthew R. via Tech-talk <[email protected]> wrote:
> > Hi,
> > Has anyone thought about adding disk space (or, rather, file system mount point) statistics and network statistics
> > to the iocStats module? Or, is there another module that can already do this? Or, is this a sensible idea?
> > This may only be relevant for soft IOCs. Also, it would be redundant for multiple soft IOCs to all be monitoring
> > disk/network use if they are running on the same machine. I am thinking about a single 'system IOC' that could
> > monitor things like:
> > Overall CPU load
> > Overall memory
> > Overall file system use (Size, %Used)
> > Overall network use (In/Out Bytes/s)
> > Not really aiming to replace dedicated system monitoring tools, but getting a few of these important parameters into
> > EPICS can be useful.
> > I know iocStats is already providing overall CPU and memory use, but not network or disk space.
> > Cheers,
> > Matt
> > STS Integrated Control System Lead Engineer
> > Spallation Neutron Source
> > Oak Ridge National Lab
- disk space / network monitor in iocStats? Pearson, Matthew R. via Tech-talk
- Re: disk space / network monitor in iocStats? Tynan Ford via Tech-talk
- Re: disk space / network monitor in iocStats? Zimoch Dirk (PSI) via Tech-talk
Re: Understanding Motor Record Heinz Junkes via Tech-talk
Re: Understanding Motor Record Torsten Bögershausen via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
