[I have tried to send this mail already but it seems lost in cyberspace. If you you got it already, sorry for the
duplication.]
At PSI, we are not using IOCMON any more but iocStats. And yes, I have added support for disk space.
Our version is here: https://github.com/paulscherrerinstitute/iocStats
This is the template (instantiate once one per disk):
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/iocAdmin/Db/iocFsStats.template
And here are the implementations for posix, vxWorks and Windows.
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/devIocStats/os/posix/osdFileSystem.c
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/devIocStats/os/vxWorks/osdFileSystem.c
https://github.com/paulscherrerinstitute/iocStats/blob/master/iocStats/devIocStats/os/WIN32/osdFileSystem.c
It uses our PSI build system and several PSI internals but you may want to merge the changes with the "official"
iocStats.
Dirk
On Mon, 2021-11-15 at 17:21 -0800, Tynan Ford via Tech-talk wrote:
> There is IOCMON from PSI that contains some network statistic support for VXWorks:
> http://epics.web.psi.ch/software/iocmon/
> We at ALS are using a similar idea from this to monitor network statistics on our linux servers. A colleague worked on
> that and we can discuss that more or share the code. We don't have disk space stats but that would be interesting.
> To address the PV duplication, we ended up separating the existing iocStats database into 2 separate files. An "IOC-
> specific" stats database and a "System-specific" database. Then for each of our soft IOC servers, we have one dummy
> soft IOC that simply loads the system stats database.
> Best,
> Tynan
> On Mon, Nov 15, 2021 at 1:00 PM Pearson, Matthew R. via Tech-talk <[email protected]> wrote:
> > Hi,
> > Has anyone thought about adding disk space (or, rather, file system mount point) statistics and network statistics
> > to the iocStats module? Or, is there another module that can already do this? Or, is this a sensible idea?
> > This may only be relevant for soft IOCs. Also, it would be redundant for multiple soft IOCs to all be monitoring
> > disk/network use if they are running on the same machine. I am thinking about a single 'system IOC' that could
> > monitor things like:
> > Overall CPU load
> > Overall memory
> > Overall file system use (Size, %Used)
> > Overall network use (In/Out Bytes/s)
> > Not really aiming to replace dedicated system monitoring tools, but getting a few of these important parameters into
> > EPICS can be useful.
> > I know iocStats is already providing overall CPU and memory use, but not network or disk space.
> > Cheers,
> > Matt
> > STS Integrated Control System Lead Engineer
> > Spallation Neutron Source
> > Oak Ridge National Lab
- Re: disk space / network monitor in iocStats? Miroslaw Dach via Tech-talk
- disk space / network monitor in iocStats? Pearson, Matthew R. via Tech-talk
- Re: disk space / network monitor in iocStats? Tynan Ford via Tech-talk
RE: disk space / network monitor in iocStats? Pearson, Matthew R. via Tech-talk
Understanding Motor Record Heinz Junkes via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
