Subject: Re: Understanding Motor Record
From: Kevin Peterson via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, Heinz Junkes <[email protected]>
Date: Thu, 18 Nov 2021 15:11:54 -0600
I merged the fix this morning.
Kevin
On 11/17/21 01:45, Torsten Bögershausen via Tech-talk wrote:
Hej again,
I think that there is a bug in the motorRecord:
The current code checks for an encoder present when the UEIP field is set to Yes.
When there is no encoder, it is reset to No.
But when a database is loaded with UEIP=Yes, and the encoder is not present,
the readback will be looking at the encoder value anyway.
I added a fix here:
<https://github.com/EuropeanSpallationSource/motor/tree/reset-ueip-if-no-encoder-present>
<https://github.com/epics-modules/motor/pull/180>
BR
/Torsten
Understanding Motor Record Heinz Junkes via Tech-talk
Re: Understanding Motor Record Mark L Rivers via Tech-talk
Re: Understanding Motor Record Torsten Bögershausen via Tech-talk
Re: Understanding Motor Record Heinz Junkes via Tech-talk
RE: Understanding Motor Record Mark L Rivers via Tech-talk
Prev: Dante R1-1 released Mark L Rivers via Tech-talk
Next: ADEiger R3-1 released Mark L Rivers via Tech-talk
Prev: Re: Understanding Motor Record Torsten Bögershausen via Tech-talk
Next: A problem with modbus reading floating point numbers 高振华 via Tech-talk
