Subject: Re: Phoebus scripts on Windows
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, "Smith, William" <[email protected]>
Date: Mon, 6 Dec 2021 15:36:04 +0000
Display scripts run inside the display. They use either jython or _javascript_, they're executed by the JVM, and they can access anything that the java code could access.
connect2j was an attempt to support C-python, so you can use packages like numpy. But of course C Python runs as a separate process outside of the JVM, so it cannot access anything that the java code could access. Good for crunching numbers, useless if you want to interact with widgets on the screen. We looked at the py4j package that basically starts a TCP server/client in both the JVM and C python and then communicates between the two so that C python can interact with the display.
That was described in the original display builder online help,
and the referenced connect2j helper is still included in the phoebus version:
In practice, it's been cumbersome and slow, so we don't advertise it any longer.
If your scripts interact with the display, you're better off removing references to connect2j and py4j and just stick to jython (or _javascript_).
-Kay
From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
Sent: Monday, December 6, 2021 10:11 AM
Subject: [EXTERNAL] Phoebus scripts on Windows
I am trying to run a Phoebus screen that uses a script. The script changes the dimensions of an image widget depending on the size PV of the image.
The screen and script works in a linux environment but not in Windows(10). In the terminal I get the error “cannot locate package connect2j”
Do I need in stall a python package, if so which one? A quick search brings up nothing for connect2j.
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Phoebus scripts on Windows Smith, William via Tech-talk
Prev: Re: Phoebus scripts on Windows 王一凡 via Tech-talk
Next: Re: CentOS Alternatives Ernesto Paiser via Tech-talk
Next: Infinite FLNK loop Daykin, Evan via Tech-talk
