Subject: Infinite FLNK loop
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 6 Dec 2021 20:43:36 +0000
Hi Tech Talk,
I have a set of three records on my IOC which asynchronously send outputs to a hardware device, call them “A, B and C”. When one of these three processes, the other two should also process.
My normal idiom is as follows:
record(ao, "A")
  field(FLNK, "B")
record(ao, "B")
  field(FLNK, "C")
record(ao, "C")
  field(FLNK, "A")
Which always works fine if the records are Soft Channels, since all three are in the same lock set and the loop is smart enough to terminate. In my case where all three go to (slow) hardware, this continues infinitely. I see here (https://epics.anl.gov/tech-talk/2006/msg00216.php)  that this was known behavior in 2006, but I’d like to see if there are any alternatives or workarounds in the following 15 or so years.
Thank you,
Evan
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: [email protected]
cid:image002.jpg@01D07041.57B6D750
Re: Infinite FLNK loop Johnson, Andrew N. via Tech-talk
Prev: Re: CentOS Alternatives Ernesto Paiser via Tech-talk
Next: Trying to use elauncher: _main_ thread failed Crisp, Daniel via Tech-talk
Prev: Re: Phoebus scripts on Windows Kasemir, Kay via Tech-talk
Next: Re: Infinite FLNK loop Johnson, Andrew N. via Tech-talk
