Subject: Quickly Connecting EPICS iocsh variables to records
To: Talk EPICS Tech <[email protected]>
Date: Wed, 8 Dec 2021 11:02:03 -1000
I have an EPICS3.14.12.8 system.
What's the easiest way to connect "variable(foo, int)" lines in my dbd file to epics records?
I have many such variables throughout my code for debugging using epicsExportAddress(int, foo) in my C code.
I think I need to make a new db or template specifying new records (eg., asub type) of all the corresponding variables. The SNAM field of these records specify C routines connecting the variable memory to the corresponding records.
Is that the best approach? Has anyone else done this sort of thing? Seeing my iocsh debug variable in a display would be super helpful.
-Matt
Re: Quickly Connecting EPICS iocsh variables to records Johnson, Andrew N. via Tech-talk
Prev: RE: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
Next: Re: Quickly Connecting EPICS iocsh variables to records Johnson, Andrew N. via Tech-talk
Prev: AW: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
