Subject: Re: Quickly Connecting EPICS iocsh variables to records
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Matt Rippa <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 8 Dec 2021 21:47:44 +0000
Hi Matt,
On Dec 8, 2021, at 3:02 PM, Matt Rippa via Tech-talk <[email protected]> wrote:
What's the easiest way to connect "variable(foo, int)" lines in my dbd file to epics records?
I have many such variables throughout my code for debugging using epicsExportAddress(int, foo) in my C code.
The code from the devSymb device support could probably be modified to make those variables available, but you’d have to replace the symbol lookup code with calls to epicsFindSymbol() (declared in epicsFindSymbol.h). I think I was originally planning to change that module to use the registered variables (possibly in addition to using epicsFindSymbol) but I never got around to actually doing that.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
Prev: Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
Next: Re: Quickly Connecting EPICS iocsh variables to records Matt Rippa via Tech-talk
