Subject: Re: EPICS_DB_INCLUDE_PATH
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Date: Wed, 15 Dec 2021 09:52:10 -0800
On 12/15/21 4:35 AM, Ralph Lange via Tech-talk wrote:
> On Wed, 15 Dec 2021 at 07:52, Alfio Rizzo via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>     So my conclusion is that giving this limitation of 256 chars of maclib parser,
>     It is wise then to never use EPICS_DB_INCLUDE_PATH in a snippet to add
>     local db path, since if you have a long list of require you may hit into trouble.
> So, indirectly, this is related to ESS's E3 development environment that keeps all dependency modules in separate locations (with long paths).
It might be reasonable feature for E3 to assemble $EPICS_DB_INCLUDE_PATH
at the same place (I think) it assembles $LD_LIBRARY_PATH.
> Using other environments and/or deployment mechanisms that don't allow parallel use of multiple versions of modules, shared things get installed into a single location, so your EPICS_DB_INCLUDE_PATH stays as short as "$(TOP)/db:$(SHARED)/db".
I sometimes begin st.cmd with a variation on the following
to avoid a need for st.cmd to change directory.
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(TOP)/db")
or
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(PWD)/../../db")
or
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", ".:../../db")
(I sometimes put instance specific .db files under "iocBoot/*/" )
And I also prefer to make use of DB_INSTALLS+= in my App/db/Makefile [1]
to copy in external db files and fragments at build time, so that the
resulting IOC (if statically linked) is self-contained.
(I mentions this because both $EPICS_DB_INCLUDE_PATH and DB_INSTALLS
seem to be fairly obscure)
[1] https://github.com/mdavidsaver/pyDevSup/blob/ea5f0d62412085dfc941e8fe758695abdfdab548/devsupApp/Db/Makefile#L17-L23
Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Simon Rose via Tech-talk
EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Michael Davidsaver via Tech-talk
RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Prev: AW: Photonic Science X-ray FDS camera Sintschuk, Michael via Tech-talk
Next: Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Prev: Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
