Hello -
In e3, the database files that are installed with a module will always be installed at the location $(module_DB) (an environment variable set by require when loading a module).
In general the e3 team at ESS recommends referencing the database file paths explicitly as opposed to relying on or manipulating EPICS_DB_INCLUDE_PATH; given that there are many modules installed together, it seems you could end up loading the "wrong" one in a possibly annoying to trace way.
Similarly, if database files are located relative to the current startup command, it would be best to explicitly reference the file as
dbLoadRecords($(E3_CMD_TOP)/path/to/database.db)
so as to remove ambiguity.
Cheers,
Simon Rose
On 2021-12-15, 18:52, "Tech-talk on behalf of Michael Davidsaver via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
On 12/15/21 4:35 AM, Ralph Lange via Tech-talk wrote:
> On Wed, 15 Dec 2021 at 07:52, Alfio Rizzo via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
> So my conclusion is that giving this limitation of 256 chars of maclib parser,
> It is wise then to never use EPICS_DB_INCLUDE_PATH in a snippet to add
> local db path, since if you have a long list of require you may hit into trouble.
> So, indirectly, this is related to ESS's E3 development environment that keeps all dependency modules in separate locations (with long paths).
It might be reasonable feature for E3 to assemble $EPICS_DB_INCLUDE_PATH
at the same place (I think) it assembles $LD_LIBRARY_PATH.
> Using other environments and/or deployment mechanisms that don't allow parallel use of multiple versions of modules, shared things get installed into a single location, so your EPICS_DB_INCLUDE_PATH stays as short as "$(TOP)/db:$(SHARED)/db".
I sometimes begin st.cmd with a variation on the following
to avoid a need for st.cmd to change directory.
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(TOP)/db")
or
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(PWD)/../../db")
or
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", ".:../../db")
(I sometimes put instance specific .db files under "iocBoot/*/" )
And I also prefer to make use of DB_INSTALLS+= in my App/db/Makefile [1]
to copy in external db files and fragments at build time, so that the
resulting IOC (if statically linked) is self-contained.
(I mentions this because both $EPICS_DB_INCLUDE_PATH and DB_INSTALLS
seem to be fairly obscure)
[1] https://github.com/mdavidsaver/pyDevSup/blob/ea5f0d62412085dfc941e8fe758695abdfdab548/devsupApp/Db/Makefile#L17-L23
- Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
- EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
- Re: EPICS_DB_INCLUDE_PATH Michael Davidsaver via Tech-talk
- RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
netDev v1.1.0 released Shuei YAMADA via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
