Subject: Re: EPICS_DB_INCLUDE_PATH
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 16 Dec 2021 19:39:35 +0100
On Thu, 16 Dec 2021 at 09:34, Simon Rose <[email protected]> wrote:
In e3, the database files that are installed with a module will always be installed at the location $(module_DB) (an environment variable set by require when loading a module).
In general the e3 team at ESS recommends referencing the database file paths explicitly as opposed to relying on or manipulating EPICS_DB_INCLUDE_PATH; given that there are many modules installed together, it seems you could end up loading the "wrong" one in a possibly annoying to trace way.
Similarly, if database files are located relative to the current startup command, it would be best to explicitly reference the file as
dbLoadRecords($(E3_CMD_TOP)/path/to/database.db)
so as to remove ambiguity.
The more problematic case are substitutions files: the name (and possibly full path) of the template database are inside the substitutions file, which itself could be under version control from a different shared support module...
Cheers,
~Ralph
Re: EPICS_DB_INCLUDE_PATH Han Lee via Tech-talk
EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Michael Davidsaver via Tech-talk
RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Re: EPICS_DB_INCLUDE_PATH Simon Rose via Tech-talk
Prev: Re: EPICS_DB_INCLUDE_PATH Simon Rose via Tech-talk
Next: Re: EPICS_DB_INCLUDE_PATH Han Lee via Tech-talk
