Simon described clearly, and his explanation is excellent for e3, and that is my design concept for e3 also according to PSI experiences.
I don't know what the current policy of e3 has. But, the original policy which I designed was to convert all substitutes files to a single DB file during the installation procedure. So, a startup script only uses several DB files instead of any others. It allows users to use other formats, but no recommendation for this. All version controls for DB and substitutes files are in standard git version controls procedure. Different versions of each module and IOC will have different DB files for production and installation.
This policy, I believe, could remove these potential issues on the DB file versioning and substitution files.
I replied to this discussion because I don't think I explained this policy enough to Timo, Simon, or others at ESS. But everything was my original design and implementation.
HTH, Han
On Thu, Dec 16, 2021 at 10:40 AM Ralph Lange via Tech-talk < [email protected]> wrote: In e3, the database files that are installed with a module will always be installed at the location $(module_DB) (an environment variable set by require when loading a module).
In general the e3 team at ESS recommends referencing the database file paths explicitly as opposed to relying on or manipulating EPICS_DB_INCLUDE_PATH; given that there are many modules installed together, it seems you could end up loading the "wrong" one in a possibly annoying to trace way.
Similarly, if database files are located relative to the current startup command, it would be best to explicitly reference the file as
dbLoadRecords($(E3_CMD_TOP)/path/to/database.db)
so as to remove ambiguity.
The more problematic case are substitutions files: the name (and possibly full path) of the template database are inside the substitutions file, which itself could be under version control from a different shared support module...
Cheers, ~Ralph
Jeong Han Lee, Dr.rer.nat Staff Scientist and Engineer Lawrence Berkeley National Laboratory 1 Cyclotron Road Mailstop 46R0161 Berkeley, CA 94720, United States Tel :+1-510-486-6163
Cell:+1-510-384-3868
- EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
- Re: EPICS_DB_INCLUDE_PATH Michael Davidsaver via Tech-talk
- RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
- Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
- Re: EPICS_DB_INCLUDE_PATH Simon Rose via Tech-talk
RE: ADVimba memory leak ? Mark Rivers via Tech-talk
<2021>
2025
2026
Camera parameters not writable in ADAravis Gofron, Kazimierz via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
