1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Start IOC automatically at boot
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Cc: Ralph Lange via Tech-talk <[email protected]>
Date: Thu, 06 Jan 2022 23:36:39 +0100
Hi Yong,
Thank you very much for your quick response and thank you for creating systemd-softioc and sharing it with the community. With your advice I got it working. procServ was not successfully installed and naturally it did not work. Once I installed procServ, everything works beautifully.
Thank you,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 06.01.2022 17:45, Hu, Yong je napisao(la):
Hi Donny,
Could you try these and post your results?
1) Type “which procServ” to see if procServ is successful
installed;
2) Type “cat /etc/systemd/system/softioc-testIOC2.service” to see
the generated service file.
Generally speaking, the main purpose of the "generic" user account
'softioc' is about permission: let ‘softioc’ be the owner of your
IOC's directory as well as the owner of your IOC's process after the
IOC is started (you can try this to see IOC processes: ps -ef | grep
st.cmd). So, you should type “sudo manage-iocs start testIOC2”
under your personal account (or the ‘root’ account).
Cheers,
Yong
"[email protected]" <[email protected]>
 ORGANIZATION: Institut Ruđer Bošković
 REPLY-TO: Donny Domagoj Cosic <[email protected]>
 DATE: Wednesday, January 5, 2022 at 3:31 PM
 TO: "[email protected]" <[email protected]>
 SUBJECT: Start IOC automatically at boot
Happy new year!
I am trying to install systemd-softioc (procServ) as outlines here
https://github.com/NSLS-II/systemd-softioc [1]. I followed the
instructions
and successfully installed it on my Raspberry Pi. I installed the IOC
and can manually start the softioc, however I am not able to start the
IOC using manage-iocs. I get the following output:
softioc@raspberrypi:/epics/iocs/testIOC2$ sudo manage-iocs start
testIOC2
Starting the IOC 'testIOC2' ...
Failed to start the IOC 'testIOC2'; type 'sudo journalctl -xe' for
details.
Below is my config file and output from the journalctl
Config
NAME=testIOC2
PORT=4053
HOST=raspberrypi
USER=softioc
CHDIR="/epics/iocs/testIOC2/iocBoot/ioctestIOC2"
EXEC="$CHDIR/st.cmd"
Output from journalctl
Jan 05 21:11:29 raspberrypi sudo[13371]: softioc : TTY=pts/0 ;
PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/manage-iocs
install testIOC2
Jan 05 21:11:29 raspberrypi sudo[13371]: pam_unix(sudo:session):
session
opened for user root by (uid=0)
session
closed for user root
Jan 05 21:11:43 raspberrypi sudo[13423]: softioc : TTY=pts/0 ;
start testIOC2
Jan 05 21:11:43 raspberrypi sudo[13423]: pam_unix(sudo:session):
session
Jan 05 21:11:43 raspberrypi systemd[1]: Reloading.
Jan 05 21:11:43 raspberrypi systemd[1]: [email protected]:
Current command vanished from the unit file, execution of the command
list won't be resume
Jan 05 21:11:43 raspberrypi systemd[1]: plexmediaserver.service:
Current
command vanished from the unit file, execution of the command list
won't
be resumed.
Jan 05 21:11:44 raspberrypi systemd[1]: Condition check resulted in
IOC
testIOC2 via procServ being skipped.
-- Subject: A start job for unit softioc-testIOC2.service has finished
successfully
-- Defined-By: systemd
-- Support:
https://urldefense.com/v3/__https://www.debian.org/support__;!!P4SdNyxKAPE!TP0CWTCKflbs_jaxGE76jgOrTY2iKe98ZI6VnTvLdIlbfMgxQBelzpZthmKH$
[2]
-- A start job for unit softioc-testIOC2.service has finished
successfully.
-- The job identifier is 1803.
Jan 05 21:11:45 raspberrypi sudo[13423]: pam_unix(sudo:session):
session
Jan 05 21:11:54 raspberrypi sudo[13487]: softioc : TTY=pts/0 ;
PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/journalctl -xe
Jan 05 21:11:54 raspberrypi sudo[13487]: pam_unix(sudo:session):
session
The softioc testIOC2 contains a few records which get updated from a
python script. Which brings me to my next questions. Is there a way to
automatically start the python script with the ioc?
Thank you very much for your help,
Regards
Donny Domagoj Cosic
https://urldefense.com/v3/__http://www.irb.hr__;!!P4SdNyxKAPE!TP0CWTCKflbs_jaxGE76jgOrTY2iKe98ZI6VnTvLdIlbfMgxQBelzvOwVQv4$
[3]
Links:
[1] https://github.com/NSLS-II/systemd-softioc
[2]
https://urldefense.com/v3/__https:/www.debian.org/support__;!!P4SdNyxKAPE!TP0CWTCKflbs_jaxGE76jgOrTY2iKe98ZI6VnTvLdIlbfMgxQBelzpZthmKH$
[3]
https://urldefense.com/v3/__http:/www.irb.hr__;!!P4SdNyxKAPE!TP0CWTCKflbs_jaxGE76jgOrTY2iKe98ZI6VnTvLdIlbfMgxQBelzvOwVQv4$
Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Re: Start IOC automatically at boot Hu, Yong via Tech-talk
Prev: RE: motor record startup Mark Rivers via Tech-talk
Next: Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Start IOC automatically at boot Hu, Yong via Tech-talk
Next: RE: Start IOC automatically at boot GAGET Alexis via Tech-talk
