1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Start IOC automatically at boot
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Cc: [email protected]
Date: Thu, 06 Jan 2022 23:40:13 +0100
I added - system "python your-python-file.py &" to my st.cmd file and when the ioc starts, the python scripts start! Thank you for the suggestion.
However when I stop the ioc, the python scripts remain running in the background. How can I get the python scripts to stop when the ioc is stopped?
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 06.01.2022 18:35, Hu, Yong je napisao(la):
Another way automatically start the python script with the ioc, simply
add this kind of line at the end of your IOC’s st.cmd:
However, you need include “system.dbd” in your IOC application. In
your application’s src/Makefile, add this kind of line:
yourIOCApplicationName_DBD += system.dbd
FROM: Tech-talk <[email protected]> on behalf of GAGET
Alexis via Tech-talk <[email protected]>
 DATE: Thursday, January 6, 2022 at 12:11 PM
 TO: Donny Domagoj Cosic <[email protected]>,
[email protected] <[email protected]>
 SUBJECT: RE: Start IOC automatically at boot
"Is there a way to automatically start the python script with the
ioc?"
-> You can simply use procServ as well to execute your python script
DE : Tech-talk <[email protected]> de la part de Donny
 ENVOYÉ : mercredi 5 janvier 2022 21:30:07
 À : Ralph Lange via Tech-talk
 OBJET : Start IOC automatically at boot
Happy new year!
 I am trying to install systemd-softioc (procServ) as outlines here
 https://github.com/NSLS-II/systemd-softioc [1]. I followed the
instructions
 and successfully installed it on my Raspberry Pi. I installed the IOC
 and can manually start the softioc, however I am not able to start
the
 IOC using manage-iocs. I get the following output:
 softioc@raspberrypi:/epics/iocs/testIOC2$ sudo manage-iocs start
 testIOC2
 Starting the IOC 'testIOC2' ...
 Failed to start the IOC 'testIOC2'; type 'sudo journalctl -xe' for
 details.
 Below is my config file and output from the journalctl
 Config
 NAME=testIOC2
 PORT=4053
 HOST=raspberrypi
 USER=softioc
 CHDIR="/epics/iocs/testIOC2/iocBoot/ioctestIOC2"
 EXEC="$CHDIR/st.cmd"
 Output from journalctl
 Jan 05 21:11:29 raspberrypi sudo[13371]: softioc : TTY=pts/0 ;
 PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/manage-iocs
 install testIOC2
 Jan 05 21:11:29 raspberrypi sudo[13371]: pam_unix(sudo:session):
session
 opened for user root by (uid=0)
session
 closed for user root
 Jan 05 21:11:43 raspberrypi sudo[13423]: softioc : TTY=pts/0 ;
 start testIOC2
 Jan 05 21:11:43 raspberrypi sudo[13423]: pam_unix(sudo:session):
session
 Jan 05 21:11:43 raspberrypi systemd[1]: Reloading.
 Jan 05 21:11:43 raspberrypi systemd[1]: [email protected]:
 Current command vanished from the unit file, execution of the command
 list won't be resume
 Jan 05 21:11:43 raspberrypi systemd[1]: plexmediaserver.service:
Current
 command vanished from the unit file, execution of the command list
won't
 be resumed.
 Jan 05 21:11:44 raspberrypi systemd[1]: Condition check resulted in
IOC
 testIOC2 via procServ being skipped.
 -- Subject: A start job for unit softioc-testIOC2.service has
finished
 successfully
 -- Defined-By: systemd
 -- Support: https://www.debian.org/support [2]
 -- A start job for unit softioc-testIOC2.service has finished
 successfully.
 -- The job identifier is 1803.
 Jan 05 21:11:45 raspberrypi sudo[13423]: pam_unix(sudo:session):
session
 Jan 05 21:11:54 raspberrypi sudo[13487]: softioc : TTY=pts/0 ;
 PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/journalctl
-xe
 Jan 05 21:11:54 raspberrypi sudo[13487]: pam_unix(sudo:session):
session
 The softioc testIOC2 contains a few records which get updated from a
 python script. Which brings me to my next questions. Is there a way
to
 automatically start the python script with the ioc?
 Thank you very much for your help,
 Regards
 Donny Domagoj Cosic
 T: +385 1 4561 041 | @: [email protected] | www.irb.hr [3]
Links:
[1] https://github.com/NSLS-II/systemd-softioc
[2]
https://urldefense.com/v3/__https:/www.debian.org/support__;!!P4SdNyxKAPE!XScIVOM_CZDyHbp9c76gj4WzN_hFVrfqEqfAzjKK-hfgXnNgknPHzlsNS57f$
[3]
https://urldefense.com/v3/__http:/www.irb.hr__;!!P4SdNyxKAPE!XScIVOM_CZDyHbp9c76gj4WzN_hFVrfqEqfAzjKK-hfgXnNgknPHznuurVW7$
Re: Start IOC automatically at boot Hu, Yong via Tech-talk
Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
RE: Start IOC automatically at boot GAGET Alexis via Tech-talk
Prev: Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Next: Re: Start IOC automatically at boot Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Start IOC automatically at boot Hu, Yong via Tech-talk
