Heinz Junkes silently set the ADEL and MDEL fields to 1.0E-9
which exactly does what we were observing.
It was just not documented on our side and I wasnt aware of the
fields existence.
Im hijacking this Thread because I have a similar problem but
the suggested solution is not working.
we have the following db:
record(stringin, "$(P):$(R):getter"){
field(DESC, "$(DESC) raw answer")
field(DTYP, "stream")
field(INP, "@maxigauge.proto getSensorValue($(CHA))
$(PORT)")
field(SCAN, "1 second")
field(FLNK, "$(P):$(R):Status.PROC CA")
record(scalcout, "$(P):$(R):Status"){
field(DESC, "$(DESC)")
field(INAA, "$(P):$(R):getter")
field(CALC, "SSCANF(AA, \"%d%*\")")
field(FLNK, "$(P):$(R):Pressure.PROC CA")
record(scalcout, "$(P):$(R):Pressure"){
field(CALC, "SSCANF(AA, \"%*2c%E\")")
field(PREC, "15")
field(EGU, "mbar")
field(ADEL, $(ADEL))
field(MDEL, $(MDEL))
this ran fine until recently.
we dont know whats wrong now...
(original code was without ".PROC CA" and with PREC "12")
the problem is that the :getter PV continiously provides new
values, while the :Status and :Pressure PVs slow down and stop
updating when the Vacuum reaches Pressures in the Range
<=1.0E-9.
>= 1.0E-7 its updating fast, around 8.0E-8 its only every
minute or so and below it basically stops.
can anybody tell me why this is happening?
I first thought it was the unsufficient PREC but appearantly it
isnt. :(
Thanks in Advance,
William
| William Kirstaedter (PP&B) |
Fritz-Haber-Institut der MPG |
| Faradayweg 4-6 |
14195 Berlin |
| Tel: 030 8413 5405 |
Mail: [email protected] |
Am 15.01.2022 um 02:25 schrieb
Randall Cayford via Tech-talk:
That worked. Thanks!
Change this line:
field (FLNK, "$(P):current1.PROC")
to:
CA")
I have a
periodic scanned PV which I occasionally set.
However, when I set it, I can’t read the updated
value until the periodic scan happens. I would
like the PV value to update as soon as it’s set.
I thought that was what was supposed to happen
with FLNK but it doesn’t seem to.
My db has:
record (ai, "$(P):current1")
field (DTYP, "stream")
field (INP, "@thorlab.proto getcurrentch(1)
$(BUS)")
field (SCAN, "10 second")
record (ao, "$(P):setcurrent1")
field (OUT, "@thorlab.proto setcurrentch(1)
$(BUS)")
field (SCAN, "Passive")
"caput setcurrent1 10" works but it takes whatever
is left of the 10 second scan period before
current1 changes.
“caput current1.PROC 1” immediately updates the
value in current1.
I tried field (FLNK, "$(P):current1”) but that
doesn’t process either.
What’s the trick for getting a periodic scan PV to
process within a forward link? Or is there some
other way I’m supposed to do this?
Thanks.
Randall
LBNL
