Another way to answer the original question, at the expense of adding an additional record, is to do this:
record(bo, “scanner”) {
field(SCAN, “10 second”)
field(FLNK, “readback”)
record(ao, “setpoint”) {
field(DTYP, “stream”)
field(OUT, “@my.proto set() portName”)
field(SCAN, “Passive”)
record(ai, “readback”) {
field(INP, “@my.proto get() portName”)
And if you have multiple readbacks then the “scanner” could be a fanout or dfanout.
The advantage of the above is that you can use put_callback to set the setpoint and immediately check the readback to see if the value was accepted, like:
bash> caput -c setpoint 10.0
bash> caget readback
which doesn’t work if you have a CA link involved.
Cheers,
Matt
On Behalf Of Ralph Lange via Tech-talk
Sent: Tuesday, January 18, 2022 10:15 AM
To: EPICS Tech Talk <[email protected]>
Subject: [EXTERNAL] Re: FLNK doesn't process
On Tue, 18 Jan 2022 at 12:06, William Kirstaedter via Tech-talk <[email protected]> wrote:
we dont know whats wrong now...
(original code was without ".PROC CA" and with PREC "12")
Targeting local FLNKs to .PROC and making them CA is only required in a few cases:
If the target record is scanned periodically.
If you need to override the loop protection in EPICS Base.
If you want to avoid putting too many records in the same lock set.
The regular cases (passive target record, "normal" use case, one-to-one FLNKing) can and should use database records.
Using database records is immediate, fast, directly coupled. Basically a call to the target record's process() routine.
Using CA to the .PROC field adds queueing, delay, thread switching. Think of it as a loosely coupled triggering of the target record "in the very near future".
- Re: [EXTERNAL] Re: FLNK doesn't process Ralph Lange via Tech-talk
- FLNK doesn't process Randall Cayford via Tech-talk
- Re: FLNK doesn't process Hu, Yong via Tech-talk
- Re: FLNK doesn't process Randall Cayford via Tech-talk
- Re: FLNK doesn't process William Kirstaedter via Tech-talk
- Re: FLNK doesn't process Ralph Lange via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
