1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Use of asyn's setInterruptUInt32Digital in EPICS device support
From: Jure Varlec via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 26 Jan 2022 09:32:07 +0100
Dear all,
I’m looking at `asynPortDriver::setInterruptUInt32Digital()' which is documented
to be “called when asyn clients call `pasynUInt32Digital->setInterrupt()'”.
However, EPICS device support (`devAsynUInt32Digital.c') does not contain such a
call.
It’s not clear to me how this interface is meant to be used. I’d expect, from
the driver point of view, to be able to use
`asynPortDriver::getInterruptUInt32Digital()' to learn which bits records are
interested in. However, this does not work with EPICS, I don’t see how it could
be set to logical-or of masks for all `IO Intr' records, and I don’t see a use
case for anything else. I don’t have a use case myself; I’m just wondering how
the interface works and what it is meant for, presuming that it was implemented
with some purpose in mind.
Actually, I feel a bit unsure as to how the mask in the UInt32Digital interface
really works. The documentation appears to be quite sparse on this topic. My
understanding is the following:
• `asynInt32' deals with the mask in EPICS device support layer support while
  `asynUInt32Digital' delegates that to the driver.
• On read or write, `asynUInt32Digital' passes the mask and the value to/from
  the driver unmodified. It’s up to the driver to apply the mask to the value
  in the way appropriate for the device.
• For interrupts, `asynPortDriver' will consider the mask given to
  `setUIntDigitalParam()' and figure out which `IO Intr' records to process
  based on both the mask and which bits in the value have changed.
If the last point is true, then I guess
`asynPortDriver::setInterruptUInt32Digital()' really doesn’t seem useful for
EPICS. I hope now you see why I’m wondering what it’s about :)
Best regards,
Jure Varlec
Senior Software Developer
Cosylab d.d.
www.cosylab.com
Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Mark Rivers via Tech-talk
Prev: Re: Interrupt problem. Johnson, Andrew N. via Tech-talk
Next: Phoebus - image on Boolean-Button Mogamad Amien Crombie via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: could you tell me how to cancel the toolbar when I deploy a opi file in tomcat by webopi3.3 ? 朱晨晨 via Tech-talk
Next: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Mark Rivers via Tech-talk
