1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Phoebus - image on Boolean-Button
From: Mogamad Amien Crombie via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 26 Jan 2022 16:00:07 +0200
Hi there.
I switched to Phoebus about 6 months ago and everything so far is working except 1 problem.
I have a 'boolean-button' with a 'on_image' that needs to change to 1 of 3 images I have.
Now when I 'run' my display, I get the default image and I need to click on the 'boolean-button' again to show the right image.
Here is my external script:
from org.csstudio.display.builder.runtime.script import PVUtil
from java import lang
a = PVUtil.getDouble(pvs[0])
s = PVUtil.getDouble(pvs[1])
## Script Body
if s==0.0:
widget.setPropertyValue('on_image', "fcup_red.png")
widget.setPropertyValue('off_image', "fcup_red.png")
elif s==64.0 or s==128.0:
widget.setPropertyValue('y', 45)
widget.setPropertyValue('on_image', "fcup.png")
widget.setPropertyValue('off_image', "fcup.png")
elif s>64.0 and s<128.0:
elif s>128:
widget.setPropertyValue('on_image', "fcup_pink.png")
widget.setPropertyValue('off_image', "fcup_pink.png")
else:
#print ("######## Done ############")
Thanks
Amien
iThemba-LABS :
South Africa
Re: [EXTERNAL] Phoebus - image on Boolean-Button Kasemir, Kay via Tech-talk
Prev: Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
Next: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
Next: Re: [EXTERNAL] Phoebus - image on Boolean-Button Kasemir, Kay via Tech-talk
