1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support
From: Jure Varlec via Tech-talk <[email protected]>
To: "[email protected] ([email protected])" <[email protected]>
Date: Thu, 27 Jan 2022 15:36:42 +0100
Excellent, thank you so much for the explanation!
Best regards,
Jure
Mark Rivers <[email protected]> writes:
> Ø  I surmise that, when you say “hardware interrupts”, you refer to the interrupt sources that a driver can enable or
> disable on the device, while with “software interrupts”, you refer to the mechanism by which the interrupts are
> propagated from the driver to the EPICS records, regardless of whether they originate in hardware or some software
> event in the driver. Correct?
> That is correct.  A common example of a software event is the driver polling the hardware, and doing the callbacks to
> process the EPICS records when the value changes.
> It appears, then, that the `asynUInt32Digital’ interface has two distinct parts:
> • `registerInterruptUser()’ and `cancelInterruptUser()’ deal with “software
>   interrupts” and allow EPICS device support layer to subscribe to events from
>   the driver;
> • `{set,get,clear}Interrupt()’ tell the driver to enable or disable particular
>   hardware interrupts. The driver needs to override the default implementation
>   of this interface to use it, like `ipUnidig’ does.
> That is correct.
> Ø  In any case, as I had pointed out, asyn’s EPICS device support layer does not have any calls to
> `{set,get,clear}Interrupt()’. So who does `ipUnidig’ implement this for? Some non-EPICS user?
> That is an excellent point.  In fact, there is currently no way to call the setInterruptUInt32Digital method in the
> IPUnidig driver from EPICS records.  The configuration of the hardware interrupts is done in the constructor using the
> risingMask and fallingMask variables passed to  initIPUnidig from the startup script, and there is currently no way to
> change them at run-time.
> If there is a need to configure the interrupts for that then there are 2 possible solutions:
> -          devAsynUInt32Digital.c could be changed to support calling the setInterrupt and clearInterrupt methods in the
> asynUInt32Digital interface.  One would need to establish a convention of the value of  the drvUser field in the record
> link field that means this is an interrupt mask, not a data value.
> -          A simpler solution for the IpUnidig would be to extend the drvUser fields it supports.  Currently these are:
> #define digitalInputString  “DIGITAL_INPUT”
> #define digitalOutputString “DIGITAL_OUTPUT”
> #define DACOutputString     “DAC_OUTPUT”
> One could add:
> #define risingMaskString  “RISING_MASK”
> #define fallingMaskString  “FALLING_MASK”
> and add these to the parameter library.
> The driver’s writeUInt32Digital method would then check the pasynUser->reason, and if it is one of these values then
> it would call the setInterruptUInt32Digital method internally.
> Mark
> —–Original Message—–
> From: Tech-talk <[email protected]> On Behalf Of Jure Varlec via Tech-talk
> Sent: Thursday, January 27, 2022 1:48 AM
> To: [email protected]
> Subject: Re: Use of asyn’s setInterruptUInt32Digital in EPICS device support
> Hello Mark,
> Thanks for the explanation, it helps a lot; I knew I was confused, of course, but not exactly where the issue was. I
> often have problems with nomenclature as various terms used in asyn are very context-dependent; in particular, I
> think I lack some background information to understand the distinction between hardware and software interrupts
> you make in this context. I surmise that, when you say “hardware interrupts”, you refer to the interrupt sources that a
> driver can enable or disable on the device, while with “software interrupts”, you refer to the mechanism by which the
> interrupts are propagated from the driver to the EPICS records, regardless of whether they originate in hardware or
> some software event in the driver. Correct?
>   the driver;
> But I may have misunderstood the distinction :)
> In any case, as I had pointed out, asyn’s EPICS device support layer does not have any calls to `{set,get,clear}Interrupt
> Thanks,
> Jure
>> Hi Jure,
>>> I’m looking at `asynPortDriver::setInterruptUInt32Digital()’ which is
>>> documented to be “called when asyn clients call
>> `pasynUInt32Digital->setInterrupt()’”.
>>> However, EPICS device support (`devAsynUInt32Digital.c’) does not contain such a call.
>> You are looking in the wrong place for that call.  That call is not
>> part of device support, it is part of the asynUInt32Digital interface, and so is present here:
>> <<https://github.com/epics-modules/asyn/blob/a2f59505766f5a19af1afb325f>
>> c84b3a1d77552f/asyn/interfaces/asynUInt32Digital.h#L44>
>> pasynUInt32Digital->setInterrupt() is used to configure the driver to control which bits will generate interrupts.
>> It is implemented in the IPUnidig driver, for example:
>> <<https://github.com/epics-modules/ipUnidig/blob/990c5920e6a50f17b164db>
>> 0477ccfdc28df97442/ipUnidigApp/src/drvIpUnidig.cpp#L543>
>>> I’d expect, from the driver point of view, to be able to use
>>> `asynPortDriver::getInterruptUInt32Digital()’ to learn
>> which bits records are interested in.
>> No, it is the reverse.  Device support calls
>> getInterruptUInt32Digital() to learn which bits the hardware has configured to generate interrupts.
>>> • On read or write, `asynUInt32Digital’ passes the mask and the value to/from in the way appropriate for the
> device.
>> Yes, that is true.
>>>  For interrupts, `asynPortDriver’ will consider the mask given to
>>> `setUIntDigitalParam()’ and figure out which `IO
>> Intr’ records to process based on both the mask and which bits in the value have changed.
>> Yes, that is true.  But this has nothing to do with driver/hardware
>> interrupts, which is what setInterruptUInt32Digital() is designed to control.
>>> If the last point is true, then I guess
>>> `asynPortDriver::setInterruptUInt32Digital()’ really doesn’t seem
>>> useful for
>> EPICS. I hope now you see why I’m wondering what it’s about
>> You are mixing up software interrupts which are handled using
>> callbacks for records with SCAN=I/O Intr with driver/hardware
>> interrupts.  They are completely separate.  asynPortDriver::setInterruptUInt32Digital() only controls driver/hardware
> interrupts, which is why it is not used in many places.
>> Mark
>> From: Tech-talk <[email protected]> on behalf of Jure
>> Sent: Wednesday, January 26, 2022 2:32 AM
>> To: [email protected] <[email protected]>
>> Subject: Use of asyn’s setInterruptUInt32Digital in EPICS device
>> support
>> Dear all,
>> documented to be “called when asyn clients call `pasynUInt32Digital->setInterrupt()’”.
>> It’s not clear to me how this interface is meant to be used. I’d
>> `asynPortDriver::getInterruptUInt32Digital()’ to learn which bits
>> records are interested in. However, this does not work with EPICS, I
>> don’t see how it could be set to logical-or of masks for all `IO Intr’
>> records, and I don’t see a use case for anything else. I don’t have a
>> use case myself; I’m just wondering how the interface works and what
>> it is meant for, presuming that it was implemented with some purpose in mind.
>> Actually, I feel a bit unsure as to how the mask in the UInt32Digital
>> interface really works. The documentation appears to be quite sparse
>> on this topic. My understanding is the following:
>> • `asynInt32’ deals with the mask in EPICS device support layer support while
>>   `asynUInt32Digital’ delegates that to the driver.
>>   the driver unmodified. It’s up to the driver to apply the mask to the value
>>   in the way appropriate for the device.
>> • For interrupts, `asynPortDriver’ will consider the mask given to
>>   `setUIntDigitalParam()’ and figure out which `IO Intr’ records to process
>> useful for EPICS. I hope now you see why I’m wondering what it’s about
>> Best regards,
>> Jure Varlec
>> Senior Software Developer
>> Cosylab d.d.
>> www.cosylab.com
Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Mark Rivers via Tech-talk
Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
RE: Use of asyn's setInterruptUInt32Digital in EPICS device support Mark Rivers via Tech-talk
Prev: RE: Use of asyn's setInterruptUInt32Digital in EPICS device support Mark Rivers via Tech-talk
Next: Re: ADVimba memory leak ? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Phoebus - image on Boolean-Button Mogamad Amien Crombie via Tech-talk
