Hi All,
I was reading through some old tech talk posts about how aliases work and had a few questions. The problem I am trying to solve is to add some level of flexibility to a piece of equipment’s PV names. I thought the alias might be a runtime
option where the operator could input to a CS Studio box a name such as “Water Level 1” which is saving to a PV “SCOPE1:DIG1:CH1.ALIAS” (after reading I don’t think this is possible though?). Currently I have each digitizer channel hardcoded with a signal
name “SCOPE1:DIG1:Water_Level_1”. The idea was to be able to rename the channels of a digitizer given what gets hooked up to each channel during runtime of the system.
From exploring tech talk posts are these the only ways to do the aliases
- Use the db command for aliases to load an alias file, is this similar to the dbLoadRecord used in the st.cmd file?
- Add an alias file into my gateway
StreamDevice 刘晓敏 via Tech-talk
Re: StreamDevice Mark Rivers via Tech-talk
<2022>
Re: 回复: StreamDevice Zimoch Dirk (PSI) via Tech-talk
RHEL8 as an NFS server for RTEMS Hu, Yong via Tech-talk
<2022>
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
