1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Timing in seq record
From: Michael Davidsaver via Tech-talk <[email protected]>
Date: Thu, 3 Mar 2022 07:56:56 -0800
On 3/3/22 05:21, Mark Rivers via Tech-talk wrote:
Hi Andrew,
Assuming that you’re seeing this on a Windows IOC I believe the fix for that was in  ...
No, as my original message said I am seeing this on Linux (Centos 7).
However, my statement that issue that Freddie referenced (106) is closed is incorrect.  That issue is still open.  That issue references several other issues that are closed, which is why I was confused.
I believe Freddie is correct in his more recent message:
There were timers waking up early, but also half a quantum being subtracted from the time value asked for, I think to give a good average wakeup time for systems when wakeup is on boundaries of the quantum. I see that this subtraction still happens
This looks like a problem of quantum/2 subtraction.
I agree that this arbitrary shortening is a ~bug, but it is worth remembering
that my attempt at removing this it caused a problem for you (Mark) on vxworks.
https://bugs.launchpad.net/epics-base/+bug/1861612/comments/12
There are some known problems with using epicsTimer for precise, short, delays.
*Sent:* Wednesday, March 2, 2022 10:17 PM
*To:* Mark Rivers <[email protected]>
*Cc:* Freddie Akeroyd - STFC UKRI <[email protected]>; [email protected] <[email protected]>
*Subject:* Re: Timing in seq record
Hi Mark,
Assuming that you’re seeing this on a Windows IOC I believe the fix for that was in GitHub PR 131 https://github.com/epics-base/epics-base/pull/131 <https://github.com/epics-base/epics-base/pull/131> which was merged into the 3.15 branch (released in 3.15.9). The 3.15 branch was then merged into the 7.0 branch prior to the release of 7.0.6 last July.
The release notes for it unfortunately don’t describe the problem very clearly or refer to the issue or pull request numbers, and because the fix came up from 3.15 they’re buried in the middle of the file, but they can be found in the 7.0 branch file at https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md#use-waitable-timers-on-microsoft-windows <https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md#use-waitable-timers-on-microsoft-windows>
- Andrew
Complicity is easy, Simplexity takes real work
On Mar 2, 2022, at 8:37 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
Hi Freddie,
Thanks for pointing out that issue.
That issue was closed on March 12, 2021, saying there has been a pull request.
7.0.6 was release on July 3, 2021, and 7.0.6.1 on October 6, 2021.  But I don't see anything about this issue in the release notes for either of these.
Is there a release of base that fixes this fairly serious issue?
*From:* Freddie Akeroyd - STFC UKRI <[email protected]>
*Sent:* Wednesday, March 2, 2022 7:54 PM
*Subject:* RE: Timing in seq record
Hi Mark,
This might be related to Timers expire early · Issue #106 · epics-base/epics-base (github.com) <https://github.com/epics-base/epics-base/issues/106> as I think it may use timers for the delay
Freddie
*From:*Tech-talk <[email protected]> *On Behalf Of *Mark Rivers via Tech-talk
*Sent:* 03 March 2022 00:35
*Cc:* [email protected]
I see the same thing with base 7.0.5.
*From:*Tech-talk <[email protected] <mailto:[email protected]>> *On Behalf Of *Mark Rivers via Tech-talk
*Sent:* Wednesday, March 2, 2022 6:31 PM
*To:* [email protected] <mailto:[email protected]>
*Subject:* Timing in seq record
I have the following simple database with a seq record which just writes 1 and 0 to the Shutter record.  There is a delay of $(DELAY) before writing 1 and before writing 0.
record(seq,"$(P)OpenCloseShutter") {
    field(PINI, "YES")
    field(DLY0,"$(DELAY)")
    field(DOL0,"1")
    field(LNK0,"$(P)Shutter PP MS")
    field(DLY1,"$(DELAY)")
    field(DOL1,"0")
    field(LNK1,"$(P)Shutter PP MS")
    field(FLNK,"$(P)OpenCloseShutter.PROC CA")
record(bo, "$(P)Shutter") {
    field(ZNAM, "Done")
    field(ONAM, "Moving")
If DELAY is 0.1 I see the following with camonitor on Shutter:
Test:Shutter                   2022-03-02 18:22:24.997849 Moving
Test:Shutter                   2022-03-02 18:22:25.092984 Done
Test:Shutter                   2022-03-02 18:22:25.188102 Moving
Test:Shutter                   2022-03-02 18:22:25.283205 Done
Test:Shutter                   2022-03-02 18:22:25.378332 Moving
Test:Shutter                   2022-03-02 18:22:25.473436 Done
Test:Shutter                   2022-03-02 18:22:25.568547 Moving
Test:Shutter                   2022-03-02 18:22:25.663681 Done
Test:Shutter                   2022-03-02 18:22:25.758885 Moving
Test:Shutter                   2022-03-02 18:22:25.854026 Done
Test:Shutter                   2022-03-02 18:22:25.949228 Moving
The period is about 190 ms rather than the expected 200 ms, but not too far off.
However, if I set DELAY=0.01 then I see this:
Test:Shutter                   2022-03-02 18:25:44.341923 Done
Test:Shutter                   2022-03-02 18:25:44.347055 Moving
Test:Shutter                   2022-03-02 18:25:44.352186 Done
Test:Shutter                   2022-03-02 18:25:44.357367 Moving
Test:Shutter                   2022-03-02 18:25:44.362523 Done
Test:Shutter                   2022-03-02 18:25:44.367682 Moving
Test:Shutter                   2022-03-02 18:25:44.372816 Done
Test:Shutter                   2022-03-02 18:25:44.377965 Moving
Test:Shutter                   2022-03-02 18:25:44.383104 Done
Test:Shutter                   2022-03-02 18:25:44.388263 Moving
Test:Shutter                   2022-03-02 18:25:44.393372 Done
Test:Shutter                   2022-03-02 18:25:44.398496 Moving
Test:Shutter                   2022-03-02 18:25:44.403633 Done
The period is 10 ms when it should be 20 ms.  The DELAY appears to be 5 ms, not 10 ms.
If I set DELAY=.005 then the Shutter PV has no monitor events.
Something seems wrong here, since I know that epicsThreadSleep on Linux is capable of good accuracy down to 100 microseconds or so.
This is base 7.0.4 on Centos 7.  Is this expected?
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Timing in seq record Andrew Johnson via Tech-talk
Timing in seq record Mark Rivers via Tech-talk
RE: Timing in seq record Mark Rivers via Tech-talk
Re: Timing in seq record Mark Rivers via Tech-talk
Re: Timing in seq record Johnson, Andrew N. via Tech-talk
Prev: RHEL8 as an NFS server for RTEMS Hu, Yong via Tech-talk
Next: Re: RHEL8 as an NFS server for RTEMS Joel Sherrill via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Timing in seq record Mark Rivers via Tech-talk
Next: Re: Timing in seq record Andrew Johnson via Tech-talk
