1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Epics Archiver Appliance and Network Storage slowdown
From: "Shankar, Murali via Tech-talk" <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 17 Mar 2022 04:43:56 +0000
You'd usually have some copy of sampleStartup.sh that you'd be using. In this you'd be setting JAVA_OPTS; something like so
export JAVA_OPTS="-XX:+UseG1GC -Xmx4G -Xms4G -ea"
You can set the parameter here
export JAVA_OPTS="-XX:+UseG1GC -Xmx4G -Xms4G -ea -Djava.util.concurrent.ForkJoinPool.common.parallelism=48"
There's usually something like a start function
function start() {
        startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/mgmt
        startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/engine
        startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/etl
        startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/retrieval
You can set the JAVA_OPTS for just the retrieval component like so...
function start() {
Again, I don't know the specifics of your setup but something like this was what I used when testing it locally.
Hope that helps.
Murali
Sent: Wednesday, March 16, 2022 6:26 PM
To: Manoussakis, Adamandios <[email protected]>; [email protected] <[email protected]>
>> What file does the JVM parameter live in that I can change?
Just whatever startup file you use.. This is just another JVM parameter.
Murali
Sent: Wednesday, March 16, 2022 5:50 PM
To: Shankar, Murali <[email protected]>; [email protected] <[email protected]>
Subject: RE: Epics Archiver Appliance and Network Storage slowdown
I am looking into the NFS mounting and if there is anything I can do to optimize performance.  Currently setup a synology 4bay DSM in Synologys version of Raid 1 with btfrs.  The AA is running on a VM with Ubuntu but havnt really had many network issues with the requests going out.
With getData could you not set the from/to at the same time and it would request at just that point in time though?
I will try to break down the requests and let each request finish before sending out the next chunk, maybe the parallel nature is just bogging down the filesystem?
Side Question:  I had posted in the issues for the github, but is there any way to use fetchLatestMetaData with getDataAtTime?
Adam
Sent: Tuesday, March 15, 2022 4:21 PM
>> For the 18000PVs that was also with getDataAtTime endpoint I assume?
Yes; this was with the getDataAtTime API call.
>> I would agree I am not completely sold on the network not being the issue
It may not be the network; may be the file system...
>> would I need to rebuild the AA or is it a config at run time read in?
It is just a config change; just an extra JVM parameter when you start up just the retrieval component.
>> Can you request multiple PVs at once with the getData endpoint?
You can but it's probably not you are looking for if you want data at some point in time.
>> they are quite a few large waveform arrays
I would try breaking these out into separate request(s) at least for testing purposes.
Murali
Sent: Tuesday, March 15, 2022 3:54 PM
Thanks for all your help Murali!
I would agree I am not completely sold on the network not being the issue but the file transfer itself was not as slow as I thought it would have been benchmarking with dd.
For the 18000PVs that was also with getDataAtTime endpoint I assume?  I am a little curious to maybe just hook up my NFS to a switch and AA PC and test out pulling directly instead of going through all the IT infrastructure of our isolated network.  Maybe be able to narrow down if it’s the network storage file access or the network itself.
I would like to try this but could you explain where I would add/change this, would I need to rebuild the AA or is it a config at run time read in?
That is correct of the 3000 PVs they are quite a few large waveform arrays causing the 40MB file size.
Other Question:  Can you request multiple PVs at once with the getData endpoint?  I wasn’t sure if I could pass a list similar to the getDataAtTime endpoint or if I would need to do pv=name1 &pv=name2&pv=name3  if it was possible?  I think we had went with the getDataAtTime due to the list of PVs option and passing a specific time (which I think I can just pass the time as from/to  as the same with getData?) but if the better way is to  execute the call I will gladly swap.
Adam
Sent: Tuesday, March 15, 2022 9:48 AM
I did some testing locally as well.
>> I do not think it has to do much with the network
I would incline to disagree (but I may be wrong); the getDataAtTime API is a secondary API ( the primary one being the getData API call) and is largely targeted at quality control for save/restore applications. The PB data formats are not necessarily optimized for this call and therefore we use a lot of parallelism to extract whatever performance we can. So, the latency of the file system calls ( and not the throughput ) is a significant factor in the performance of this API call.
For example, in my test system (using NFS as my MTS), I am able to get 18000 PV's in 42 seconds. In one of my production systems (with some real data variance), I am able to get 9000 PV's in 9 seconds. In all of these systems, there is probably an upper limit after which we run out of some resource further downstream.
The most obvious one is the size of the ForkJoin common thread pool and I tested this in a different production system ( with a slightly older GPFS). I was able to improve performance in the same system by increasing the ForkJoin common thread pool size. So this is a 12 core/24 thread CPU. With the default ForkJoin common thread pool size, I get 9000 PV's in a minute. By increasing this to 48
( -Djava.util.concurrent.ForkJoinPool.common.parallelism=48 )
and then to 64
( -Djava.util.concurrent.ForkJoinPool.common.parallelism=64 )
I was able to reduce this to 30 seconds or less. So, based on your setup, you could try a similar thing and see if it makes a difference. Alternatively, you can also try reducing this to see if the performance is the result of some starvation someplace.
>> file size for the 3000 PVs is about 40MB only
I still do not understand this; 18000 scalar PV's for me are 2MB. How does 3000 PV's become 40MB in your situation ( unless you have large some waveforms in the mix)?
Hope that helps.
Murali
Sent: Monday, March 14, 2022 5:46 PM
[email protected]>; Shankar, Murali <[email protected]>; [email protected] <[email protected]>
Hi Murali,
I had some data back from testing, the http post request is asking for about 3000 PVs from the AA which stores about 4500 PVs Total in the LTS.
I did the benchmark test to just transfer a single pb file and was getting around 100MB/s, so I do not think it has to do much with the network since the file size for the 3000 PVs is about 40MB only.  I then reduced the request down to about 1200 PVs and it definitely sped up quite a bit around 15 seconds from the 2.5mins it was taking.  Someone mentioned the lookup time for each PV was log(n) or nlog(n) for the AA but then that doesn’t seem like it would impact going from 1200 to 3000 in the POST.
I am curious how many PVs you usually request in a single http  when requesting from the AA, is there an upper limit I should stick to?  You mentioned possibly breaking up the requests into smaller chunks.
Thanks
Adam
From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Sunday, February 20, 2022 10:44 PM
Thanks Murali,
I will try to run some more tests including the one that was mentioned to make sure the transfer rates look correct.  I cant imagine the local vs NAS on this small of a setup shouldnt be vastly different.
From: Tech-talk <[email protected]> On Behalf Of Shankar, Murali via Tech-talk
Sent: Thursday, February 17, 2022 12:01 PM
To: [email protected]
>> I think for this experiment its only 6000 PVs
I think that should not take this long. Will look into this a bit here as well.
Murali
Sent: Saturday, February 12, 2022 8:03 AM
To:
>> We are using the getDataAtTime endpoint
>> 40MB file from the archive
By this I'd guess that you are getting data for several 100,000's of PVs? The getDataAtTime API call has to look at all these 100,000 files ( with perhaps cache-misses for most of them ) and then do binary search to determine the data point. Your NAS needs to support quite a high rate of IOPS to for this to come back quickly. And this is a usecase where even the smallest latency tends to accumulate quickly. Perhaps you can consider breaking down your request into smaller chunks when using the NAS?
Murali
RE: Epics Archiver Appliance and Network Storage slowdown Manoussakis, Adamandios via Tech-talk
Re: Epics Archiver Appliance and Network Storage slowdown Shankar, Murali via Tech-talk
Prev: Re: Epics Archiver Appliance and Network Storage slowdown Shankar, Murali via Tech-talk
Next: Unknown error with an equipment TONY YU via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: RE: Epics Archiver Appliance and Network Storage slowdown Manoussakis, Adamandios via Tech-talk
