Hello, I encountered an unsolvable error with one of my equipment. Below is the error and the corresponding st.cmd, db and proto files. I would like to know what causes this error message. Thanks in advance. IDEA ImpMik:IDEA:Status: Input "#31 hv error detect" mismatch after 4 bytes IDEA ImpMik:IDEA:Status: got "hv error detect" where "ok" was expected IDEA ImpMik:IDEA:SetFilterOn: Input "#2E impossible, erro" mismatch after 1 byte IDEA ImpMik:IDEA:SetFilterOn: got "2E impossible, error" where "0" was expected st.cmd: drvAsynIPPortConfigure("IDEA", "terminal.chamber6:10002") asynOctetSetInputEos("IDEA",0,"\r\n") asynOctetSetOutputEos("IDEA",0,"\r\n") dbLoadRecords("${TOP}/db/Impulsmikroskop/IDEA.db", "P=ImpMik, NAME=IDEA, interface=IDEA") IDEA.db: record(bi, "$(P):$(NAME):Status") { field(PINI, "YES") field(DTYP, "stream") field(INP, "@IDEA.proto Get_Status $(interface)") field(ZNAM, "ERR") field(ONAM, "Ok") } record(bo, "$(P):$(NAME):SetFilterOn") { field(SCAN, "2 second") field(DTYP, "stream") field(FLNK, "$(P):$(NAME):SetEpass") field(OUT, "@IDEA.proto Set_FilterOn $(interface)") field(ZNAM, "Off") field(ONAM, "On") } IDEA.proto: terminator = CR LF; pollperiod = 10; replytimeout = 1000; readtimeout = 5000; # # Get_Status # Get_Status { out "Get status"; in "#%2i ok"; out "ver"; in "EFC_for_NanoESCA V01.03 B0115"; out "Set mode remote"; in "#04 remote mode"; } # # Set_FilterOn # range: 1, 10 # Set_FilterOn { out "Set filter %{off|on}"; in "#0%*c filter %{off|on}"; @init { out "Get filter"; in "#0%*c filter %{off|on}"; } } Best, Tony
ANJ, 14 Sep 2022 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
