We have motorRecord 7.1 and the motorPhytron support. This works fine with the phyMotion module I1AM01, controler with power stage. Now we want to use the indexer module I1EM01 and find that the motorRecord send its go to 0 position before the reference
on the limit switch is finished by the motor controller. The limit switch is reached but before the motor controller sends its HALT signal, set its position to 0 and its DONE status, the motorRecord send a go to 0-Posiion command. this will end up in a undefined position. The phyMotion reference to a switch will
hit the switch, slow down and leave it. Than the reference is done and the position set to 0 The Question is, how does the motorRecord recognise a finished reference. In the phytronMotor driver there are following status bits processed in the ::poll(*moving) function: - *moving: phyMotion command "Mn.m==H" response shows halt or move - Status bits for limit switches to the according axis controller variables and bit for initialised for motor status home - INITIALISED -> pC_->motorStatusHome_ - setIntegerParam(pC_->axisStatus_, axisStatus); I suppose INITIALISED is used to flag the record home is done. At last, the whole axisStatus will be set to the axis controller. This controler status is not the motorRecord.MSTA What I found in the sources is that it is there compared to the old status
to recognise changes, but not any processing of single bits. Each controler would have its own bits, so it wouldn't make sense to process it in the motorRecord.
Relay strange is, that it works with the other module. There are some other status bits set e.g. the PositioningMode bit, but all these is not used by the phytronMotor support. The following beautified log of the IP-Port shows that the motorRecord sends a move command before this is done: M1.1P20R reads the position M1.1==H checks for motor running M1.1SE read the motor status. The strings show "isInit DONE" if motor is idle and bits that change while performing any action M1.1R+ The reference command M1.1An move to absolute position * Motor is idle 15:20:08.052 wr M1.1==H 15:20:08.063 rd E 15:20:08.063 wr M1.1SE 15:20:08.072 rd 1573384, 0x180208 STAT:0x180208 STAT: isInit DONE * HOMF command: set move parameters and home command: M1.1R 15:20:08.382 wr M1.1P08=1000.000000 15:20:08.393 rd 15:20:08.393 wr M1.1P10=180.000000 15:20:08.402 rd 15:20:08.403 wr M1.1P09=4000.000000 15:20:08.412 rd 15:20:08.412 wr M1.1R+ 15:20:08.422 rd 15:20:08.422 wr M1.1P20R 15:20:08.432 rd 1 15:20:08.443 wr M1.1==H 15:20:08.452 rd N 15:20:08.452 wr M1.1SE 15:20:08.462 rd 1050113, 0x100601 STAT:0x100601 STAT: busy Ramp 15:20:08.933 wr M1.1P20R 15:20:08.942 rd 416 15:20:08.952 wr M1.1==H 15:20:08.962 rd N 15:20:08.962 wr M1.1SE 15:20:08.972 rd 1049089, 0x100201 STAT:0x100201 STAT: busy 15:20:09.432 wr M1.1P20R 15:20:09.442 rd 917 Motor moves forward 15:20:47.016 wr M1.1==H 15:20:47.036 rd N 15:20:47.036 wr M1.1SE 15:20:47.046 rd 1049089, 0x100201 STAT:0x100201 STAT: busy 15:20:47.496 wr M1.1P20R 15:20:47.507 rd 38969 15:20:47.516 wr M1.1==H 15:20:47.526 rd N 15:20:47.526 wr M1.1SE * Motor hit LS+ switch, ramp down and try to leave the LS+ switch slowly. If this is done, it will reset the position to 0 and set halt and isInit bit, but.... 15:20:47.536 rd 1050129, 0x100611 STAT:0x100611 STAT: busy LS+ Ramp 15:20:47.736 wr M1.1P20R 15:20:47.746 rd 39031 15:20:47.756 wr M1.1==H 15:20:47.766 rd N 15:20:47.766 wr M1.1SE 15:20:47.776 rd 1049105, 0x100211 STAT:0x100211 STAT: busy LS+ 15:20:47.776 wr M1.1SE 15:20:47.786 rd 1049105, 0x100211 STAT:0x100211 STAT: busy LS+ ... before this is done there is the go to 0 command from the motorRecord! 15:20:47.786 wr M1.1P14=1000.000000 15:20:47.796 rd 15:20:47.796 wr M1.1P04=180.000000 15:20:47.806 rd 15:20:47.806 wr M1.1P15=4000.000000 15:20:47.816 rd * because the motorRecord.OFF field is 0 here, the command is go to 0 15:20:47.816 wr M1.1A0 15:20:47.851 rd 15:20:47.860 wr M1.1P20R 15:20:47.866 rd 39019 15:20:47.876 wr M1.1==H 15:20:47.886 rd N 15:20:47.886 wr M1.1SE 15:20:47.897 rd 1050129, 0x100611 STAT:0x100611 STAT: busy LS+ Ramp 15:20:48.356 wr M1.1P20R 15:20:48.366 rd 38609 15:20:48.376 wr M1.1==H 15:20:48.386 rd N 15:20:48.386 wr M1.1SE 15:20:48.396 rd 1049089, 0x100201 STAT:0x100201 STAT: busy 15:20:48.846 wr M1.1P20R 15:20:48.856 rd 38118 15:20:48.866 wr M1.1==H 15:20:48.876 rd N 15:20:48.886 rd 1049089, 0x100201 STAT:0x100201 STAT: busy 15:20:49.336 wr M1.1P20R 15:20:49.347 rd 37628 Helmholtz-Zentrum Berlin für Materialien und Energie GmbH Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V. Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking Sitz Berlin, AG Charlottenburg, 89 HRB 5583 Postadresse: Hahn-Meitner-Platz 1 14109 Berlin Deutschland
ANJ, 14 Sep 2022 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
