Hi
i'm using Phoebus and have a ScrollBar widget.
I'm using master 2021-07-29 17:51 Phoebus version
running on my Ubuntu 20.04 pc. (jdk 16.02)
I however cannot set the scrollbar's value in my script.
Here a part of my python script :
from org.csstudio.display.builder.runtime.script import PVUtil
ScriptUtil
print ("Dup Range")
scrollB = ScriptUtil.findWidgetByName(widget, "Scrollbar")
scrollB.setPropertyValue("$(pv_value)", 1.0) # I
need to set my scrollBar to 1.0 after range change trigger..not
working
and the following error I get:
2022-03-24 11:17:11 WARNING
[org.csstudio.display.builder.runtime] Script execution failed
Display 'EmbeddedDisplay Embedded-Harp.bob', Widget 'Spinner_4'
(choice), JythonScript Live/duplicate_range.py
Traceback (most recent call last):
File "Live/duplicate_range.py", line 7, in <module>
at
org.csstudio.display.builder.model.Widget.getProperty(Widget.java:590)
at
org.csstudio.display.builder.model.Widget.setPropertyValue(Widget.java:722)
at
jdk.internal.reflect.GeneratedMethodAccessor5.invoke(Unknown
Source)
at
java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at
java.base/java.lang.reflect.Method.invoke(Method.java:567)
java.lang.IllegalArgumentException:
java.lang.IllegalArgumentException: Widget 'Scrollbar'
(scrollbar) has no '$(pv_value)' property
Thanks
Amien Crombie (iThemba-LABS, South Africa)
- Re: [EXTERNAL] ScrollBar in Phoebus - cannot set $(pv_value) in script Kasemir, Kay via Tech-talk
About checksum error 李姣赛 via Tech-talk
motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
<2022>
Re: About checksum error Ralph Lange via Tech-talk
<2022>
