1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Static Build on armv7
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 30 Mar 2022 16:15:40 +0200
Hey all,
we use docker images to easily deploy our IOCs for our detector control system.
The images are build for amd64, arm64/aarch64 and armv7.
To reduce the size of those images, I recently switched from dynamic to static linking by adding the line
>      && echo "STATIC_BUILD=YES" >> configure/CONFIG_SITE.local \
to our Dockerfile.
When compiling base7 for amd64 and aarch64 this is working just fine, but I get an error on arm/v7:
#0 189.7 Installing created executable /epics/base/bin/linux-arm/antelope
#0 190.1 /epics/base/bin/linux-arm/antelope -bparse -l -d ../flex/parse.y
#0 190.1 /usr/lib/ld.so.1: No such file or directory
#0 198.7 Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
I investigated the issue a bit closer and found the following:
root@195e454a8580:/epics/src/base# ldd /epics/base/bin/linux-arm/antelope
  linux-vdso.so.1 (0x7ef10000)
  libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76e71000)
  /usr/lib/ld.so.1 => /lib/ld-linux-armhf.so.3 (0x76f70000)
root@195e454a8580:/epics/src/base# ls /usr/lib/ld.so.1
ls: cannot access '/usr/lib/ld.so.1': No such file or directory
For some reason antelope gets linked against /usr/lib/ld.so.1 on armv7 but this file does not exist.
Does anyone know what causes this issue?
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Prev: softIoc compiling-in relative path to softIoc.dbd Daykin, Evan via Tech-talk
Next: Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: softIoc compiling-in relative path to softIoc.dbd Daykin, Evan via Tech-talk
