1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: softIoc compiling-in relative path to softIoc.dbd
From: "Daykin, Evan via Tech-talk" <[email protected]>
Date: Wed, 30 Mar 2022 12:55:44 +0000
Hi tech-talk,
I am finishing up a Debian package for base 7.0.6. In the finished product, I discovered that the compiled-in path to softIoc.dbd is not what I expect. I would like the path to be /usr/lib/epics/dbd/softIoc.dbd, but it is instead always pointing to <pwd>/../../dbd/softIoc.dbd, no matter where the softIoc executable resides. This causes an issue, since the Debian package drops the executables in /usr/bin, with symlinks to those executables in /usr/lib/epics. Thus, the calculated DBD path is /usr/bin/../../dbd/softIoc.dbd, which points to nothing.
If I understand correctly, this is happening like so:
1.       modules/database/src/std/softIoc/RULES generates epicsInstallDir.h by calling makeInstallDir.pl “$(FINAL_LOCATION)”. (resolves to /usr/lib/epics)
2.       softMain.cpp pulls in the EPICS_BASE #define macro from epicsInstallDir.h.
3.       softMain.cpp creates a constant DBD_FILE, defined as EPICS_BASE/dbd/softIoc.dbd
4.       softMain.cpp’s main method attempts to calculate a relative path based on DBD_FILE, and this is ultimately what is used.
So my question is, what is the preferred course of action here?
-          Re-arrange the package to drop executables in $(EPICS_BASE)/bin/$(EPICS_HOST_ARCH), and link to them from /usr/bin?
-          Add a compile-time flag to insist on an absolute path?
-          Something else?
Thank you,
Evan
Re: softIoc compiling-in relative path to softIoc.dbd Michael Davidsaver via Tech-talk
Prev: Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Next: Static Build on armv7 Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Prologix question Eric Norum via Tech-talk
Next: Re: softIoc compiling-in relative path to softIoc.dbd Michael Davidsaver via Tech-talk
