Subject: |
Re: motorRecord with phytron support: record send goto 0 command before reference is done |
Bernhard Kuner via Tech-talk <[email protected]> |
To: |
Torsten Bögershausen <[email protected]> |
Cc: |
EPICS Tech Talk <[email protected]> |
Date: |
Wed, 30 Mar 2022 12:54:31 +0200 |
@Torsten: Phymotion works as you explained: hit the switch, leave slowly
and than reset counter and send motor halt status. So the motor changes
its moving direction and the record treat this no longer as ls_active
and so as reference is done.
https://github.com/epics-modules/motor/blob/master/motorApp/MotorSrc/motorRecord.cc#L3697
Kevin: I like your idea to program around in the phytronAxis controller.
Thats what I'll do. Ok, not the best solution, but I'm afraid of
patching the motorRecord - without overlook to all implications of other
supports.
Thank you very much for your help.
Best regards
Bernhard
On 29 Mar 2022, at 16:06, Bernhard.Kuner via Tech-talk <[email protected]> wrote:
Hallo Kevin,
thank You for the help to understand what happens in the motorRecord,
nasty beast this record!
The homing type is here on the positive end-switch "Mn.m+". Poll period
0.5s but ACCL=2.0
There was a bug in the phyMotion software if you use the positive
end-switch, but there is an update from phytron and now it works if you
give this command by the phyLogic software.
Ok, You say the record recognises a motor action to be done by
pC_->motorStatusDone_ This is set in the poll routine by the command
"Mn.m==H". In the log you can see that there is no "M1.1==H" with the
answer "E" for done after hitting the end-switch and before the new move
comand occurs. So we suppose a problem in the record.
I think that there may be a potential problem in the motorRecord itself.
The first one is that the record assumes that a motor is “done”,
when a limit switch is hit:
<https://github.com/epics-modules/motor/blob/master/motorApp/MotorSrc/motorRecord.cc#L3707>
While this may be true for some controllers, it is not, especially for modern controllers
that have a “homing sequence” which looks like
“hit the limit switch, once activated, revert and drive slowly until the switch is released”
I don’t have a Phytron to test this.
If you have time to modify the motorRecord itself and test, you can modify line 3707
from above.
By the way, we have a support for the phytron IO modules. There I
introduced support for stringout -in Record to communicate with the
motor controller. If you send a home command this way, it works as expected.
Bernhard
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Postadresse:
14109 Berlin
Deutschland
- motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
- Re: motorRecord with phytron support: record send goto 0 command before reference is done Kevin Peterson via Tech-talk
- Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard.Kuner via Tech-talk
- Re: motorRecord with phytron support: record send goto 0 command before reference is done Torsten Bögershausen via Tech-talk
softIoc compiling-in relative path to softIoc.dbd Daykin, Evan via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
