1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: motorRecord with phytron support: record send goto 0 command before reference is done
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Bernhard.Kuner" <[email protected]>, [email protected]
Date: Tue, 29 Mar 2022 16:24:43 -0500
Bernhard,
With ACCL=2.0 the desired acceleration would be 410 steps/s^2, but the driver hard-codes the minimum acceleration to 4000 steps/s^2:
https://github.com/epics-motor/motorPhytron/blob/master/phytronApp/src/phytronAxisMotor.h#L21
The minimum acceleration is enforced here:
https://github.com/epics-motor/motorPhytron/blob/9acb974257dc61512017f18f9b823be0495e948d/phytronApp/src/phytronAxisMotor.cpp#L705-L706
I thought the problem might be due to an acceleration time that is significantly longer than the poll period, which might result in the controller still decelerating when EPICS sees the limit is hit, but that doesn't explain the behavior you're seeing.
Does the motor record that fails to home properly have a nonzero backlash distance (BDST) or a non-zero retry count (RTRY)?
There are only four places in the motor record code where moves are commanded. One is where normal moves and retries are commanded. The other three are related to backlash correction.
Kevin
On 3/29/22 09:06, Bernhard.Kuner wrote:
Hallo Kevin,
thank You for the help to understand what happens in the motorRecord,
nasty  beast this record!
The homing type is here on the positive end-switch "Mn.m+". Poll period
0.5s but ACCL=2.0
There was a bug in the phyMotion software if you use the positive
end-switch, but there is an update from phytron and now it works if you
give this command by the phyLogic software.
Ok, You say the record recognises a motor action to be done by
pC_->motorStatusDone_  This is set in the poll routine by the command
"Mn.m==H". In the log you can see that there is no "M1.1==H" with the
answer "E" for done after hitting the end-switch and before the new move
comand occurs. So we suppose a problem in the record.
By the way, we have a support for the phytron IO modules. There I
introduced support for stringout -in Record to communicate with the
motor controller. If you send a home command this way, it works as expected.
Bernhard
motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Re: motorRecord with phytron support: record send goto 0 command before reference is done Kevin Peterson via Tech-talk
Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard.Kuner via Tech-talk
Prev: Re: motorRecord with phytron support: record send goto 0 command before reference is done Kevin Peterson via Tech-talk
Next: Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Next: newbie question : one shot measurement Jérôme Poincheval via Tech-talk
