1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Static Build on armv7
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Maren Purves <[email protected]>
Cc: [email protected]
Date: Wed, 30 Mar 2022 14:28:25 -0700
On 3/30/22 12:32, Maren Purves wrote:
I wasn't talking about  renaming libraries but linking versions of the same one.
In this context there is no difference in effect 'cp' vs. 'ln -s'.
Done it many times.
On Wed, Mar 30, 2022 at 9:21 AM Michael Davidsaver
<[email protected]> wrote:
On 3/30/22 11:57, Maren Purves wrote:
If you have a different version of /usr/lib/ld.so.1 you could  try a
soft link to there.
It quite often works.
Please be careful with this.  Library names are different for a reason.
Blindly renaming/linking shared libraries is setting yourself up for
confusing error messages if your are lucky, and inexplicable corruption
or crashes if you are not!
Maren
On Wed, Mar 30, 2022 at 8:02 AM Michael Davidsaver via Tech-talk
On 3/30/22 10:32, Florian Feldbauer wrote:
Hey Michael,
attached is the complete output from make and the readelf command you mentioned.
   From the readelf output:
[Requesting program interpreter: /usr/lib/ld.so.1]
If this file isn't present on target system, this is a sign that you are
trying to use a toolchain for a (slightly) different target.  The best
thing you can do is to sort out this incompatibility.
Static Build on armv7 Florian Feldbauer via Tech-talk
Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Re: Static Build on armv7 Florian Feldbauer via Tech-talk
Re: Static Build on armv7 Maren Purves via Tech-talk
Prev: Re: Static Build on armv7 Maren Purves via Tech-talk
Next: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Static Build on armv7 Florian Feldbauer via Tech-talk
