1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Static Build on armv7
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Date: Thu, 31 Mar 2022 10:50:00 +0200
Hey Michael,
On 3/30/22 20:02, Michael Davidsaver wrote:
On 3/30/22 10:32, Florian Feldbauer wrote:
Hey Michael,
attached is the complete output from make and the readelf command you mentioned.
From the readelf output:
[Requesting program interpreter: /usr/lib/ld.so.1]
If this file isn't present on target system, this is a sign that you are
trying to use a toolchain for a (slightly) different target.  The best
thing you can do is to sort out this incompatibility.
Instead of doing a multi-arch build with docker buildx on my amd64 host I tried to build epics base directly on a raspi 3B+ (setting STATIC_BUILD to YES):
/usr/bin/g++ -o antelope -static -L/home/pi/epics-base/lib/linux-arm -Wl,-rpath,/home/pi/epics-base/lib/linux-arm -rdynamic         closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o     -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing created executable ../../../../bin/linux-arm/antelope
/home/pi/epics-base/bin/linux-arm/antelope -bparse -l -d ../flex/parse.y
make[4]: /home/pi/epics-base/bin/linux-arm/antelope: No such file or directory ^Cmake[3]: *** [../../../configure/RULES_ARCHS:58: install.linux-arm] Interrupt
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Interrupt
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Interrupt
make: *** [configure/RULES_DIRS:85: modules.install] Interrupt
pi@raspberrypi:epics-base $ ldd /home/pi/epics-base/bin/linux-arm/antelope
    linux-vdso.so.1 (0x7ef59000)
    /usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0x76ef1000)
    libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76d9d000)
    /usr/lib/ld.so.1 => /lib/ld-linux-armhf.so.3 (0x76f06000)
pi@raspberrypi:epics-base $ ll /usr/lib/ld.so.1
ls: cannot access '/usr/lib/ld.so.1': No such file or directory
pi@raspberrypi:epics-base $ ll /lib/ld-linux-armhf.so.3
lrwxrwxrwx 1 root root 30 Dec  1 11:52 /lib/ld-linux-armhf.so.3 -> arm-linux-gnueabihf/ld-2.31.so
As you can see, the result is the same as within docker and qemu.
antelope gets linked to /usr/lib/ld.so.1 which points to /lib/ld-linux-armhf.so.3.
The first does not exist on the system, but the latter does.
I doubt that the official Raspbian OS is using the wrong toolchain, also this only happens when having STATIC_BUILD=YES in configure/CONFIG_SITE
Therefore I compared the command used to build antelope on arm with the command used on amd64:
/usr/bin/g++ -o antelope -static -L/epics/base/lib/linux-arm -Wl,-rpath,/epics/base/lib/linux-arm          -rdynamic closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/g++ -o antelope -Wl,-Bstatic -L/epics/base/lib/linux-x86_64 -Wl,-rpath,/epics/base/lib/linux-x86_64          -rdynamic -m64         closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
On arm it uses `-static` while on amd64 it used `-Wl,-Bstatic`...I was able to pin this issue down to the following difference:
$ cat configure/os/CONFIG.linux-arm.linux-arm
# CONFIG.linux-arm.linux-arm
# Definitions for native linux-arm builds
# Sites may override these definitions in CONFIG_SITE.linux-arm.linux-arm
# Include common gnu compiler definitions
include $(CONFIG)/CONFIG.gnuCommon
$ cat configure/os/CONFIG.linux-x86.linux-x86
#  CONFIG.linux-x86.linux-x86
# Definitions for linux-x86 host - linux-x86 target builds
# Sites may override these definitions in CONFIG_SITE.linux-x86.linux-x86
STATIC_LDFLAGS_YES= -Wl,-Bstatic
STATIC_LDFLAGS_NO=
STATIC_LDLIBS_YES= -Wl,-Bdynamic
STATIC_LDLIBS_NO=
Adding those 4 last rows from CONFIG_SITE.linux-x86.linux-x86 to CONFIG_SITE.linux-arm.linux-arm solved my issue.
Now static build also works on armv7.
Cheers,
Florian
Alternately, you could path Base to remove references to "-Wl,-Bdynamic",
which would result in a fully static executable (with the limitations
which this implies).
However, you may later encounter strange linker errors and/or crashes
if object code from different, somewhat incompatible, toolchains are
being linked together.  So I would encourage you to investigate the
toolchain(s) first.
Cheers,
Florian
Am 30.03.2022 um 17:47 schrieb Michael Davidsaver:
On 3/30/22 07:15, Florian Feldbauer via Tech-talk wrote:
Hey all,
we use docker images to easily deploy our IOCs for our detector control system.
The images are build for amd64, arm64/aarch64 and armv7.
To reduce the size of those images, I recently switched from dynamic to static linking by adding the line
 >      && echo "STATIC_BUILD=YES" >> configure/CONFIG_SITE.local \
to our Dockerfile.
When compiling base7 for amd64 and aarch64 this is working just fine, but I get an error on arm/v7:
#0 189.7 Installing created executable /epics/base/bin/linux-arm/antelope #0 190.1 /epics/base/bin/linux-arm/antelope -bparse -l -d ../flex/parse.y
#0 190.1 /usr/lib/ld.so.1: No such file or directory
#0 198.7 Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
I investigated the issue a bit closer and found the following:
root@195e454a8580:/epics/src/base# ldd /epics/base/bin/linux-arm/antelope
  linux-vdso.so.1 (0x7ef10000)
  libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76e71000)
  /usr/lib/ld.so.1 => /lib/ld-linux-armhf.so.3 (0x76f70000)
It looks like "STATIC_BUILD=YES" was ignored.
root@195e454a8580:/epics/src/base# ls /usr/lib/ld.so.1
For some reason antelope gets linked against /usr/lib/ld.so.1 on armv7 but this file does not exist.
Does anyone know what causes this issue?
It would help if you could attach, or post somewhat, the complete
output of a clean 'make'.
Also the output of:
readelf -aW /epics/base/bin/linux-arm/antelope
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Static Build on armv7 Florian Feldbauer via Tech-talk
Re: Static Build on armv7 Florian Feldbauer via Tech-talk
Prev: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Next: Re: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Next: Re: Static Build on armv7 Michael Davidsaver via Tech-talk
