Hi Jong,
You are using asyn R4-38 and are worried because motor R7-2 says it needs asyn R4-37.
This is not a problem. We try hard to maintain backwards compatibility in asyn releases, so it is safe to use a newer release. Newer releases are recommended, since more bugs are fixed. If a release breaks backward compatibility then
that is discussed in the release notes.
On Behalf Of Jong Woo Kim via Tech-talk
Sent: Wednesday, April 6, 2022 1:20 PM
To: [email protected]
Subject: Compatibility of motor record with submodules
We are planning to install and build motor record for PI C-887.
According to the above website, R7-1 requires the following submodules.
The following is our EPICS info.
base-3.15.6; SynApps-6-1; motor-R7-1
I am worried about the compatibility issue.
What about installation of R7-2? because required submodules are the same as ours except Asyn.
- Compatibility of motor record with submodules Jong Woo Kim via Tech-talk
RE: synApps_6_1 and base_7.0.6.1 Mark Rivers via Tech-talk
Driver for Symetrie hexapods? Mark Rivers via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
