1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Can't properly restrict IOC CA server to an interface
From: Jure Varlec via Tech-talk <[email protected]>
Date: Fri, 8 Apr 2022 08:11:32 +0000
Dear all,
I'm pulling my hair out over an issue that only appears sometimes and I can't determine the reason for it. I have a bridge interface with IP address 10.1.1.1. It is NAT-ed to the outside world and is running DHCP and DNS for containers and VMs. The latter have their interfaces bridged there; in short, it's an internal network on 10.1.1.0/24. Apart from NAT, no other iptables rules are in place.
I would like to restrict EPICS to this internal network. Nothing needs to be done for VMs and containers as they only see the internal network anyway. CA between VMs works as expected. The problem is with the IOCs on the host where I have set (this is EPICS 7.0.6.1)
EPICS_CAS_INTF_ADDR_LIST=10.1.1.1
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_ADDR_LIST=10.1.1.255
This appears to restrict the IOC CA server to the bridge interface, as intended:
epics> casr 5
Channel Access Server V4.13
No clients connected.
CAS-TCP server on 10.1.1.1:5064 with
   CAS-UDP unicast name server on 10.1.1.1:5064
       Last name requested by 0.0.0.0:0:
       User '', V4.0, Priority = 0, 0 Channels
       Task Id = 0x2245a30, Socket FD = 7
       214.35 secs since last send, 214.35 secs since last receive
       Unprocessed request bytes = 0, Undelivered response bytes = 16
       State = up
   CAS-UDP broadcast name server on 10.1.1.255:5064
       Task Id = 0x2245c80, Socket FD = 7
       State = up
Sending CAS-beacons to 1 address:
   10.1.1.255:5065
However, it only works sometimes; other times (i.e. after a reboot or several, and more often than not), this happens:
$ caget test:arg_echo
CAC: Unable to connect because "Connection refused"
CA.Client.Exception...............................................
   Warning: "Virtual circuit disconnect"
   Context: "192.168.11.237:5064"
   Source File: ../cac.cpp line 1237
   Current Time: Thu Apr 07 2022 20:19:45.727753820
Channel connect timed out: 'test:arg_echo' not found.
The IP address shown here is the IP of the WiFi interface, which should not have been involved at all. The problem does not originate from the client. Here is the packet dissection of the CA search and response, relevant fields of IP and CA frames only:
Search:
 "ip.src": "10.1.1.1",
 "ip.dst": "10.1.1.255"
 "ca.command": "0x00000006",
 "ca.size": "16",
 "ca.doreply": "0x00000005",
 "ca.version": "13",
 "ca.cid": "1",
 "ca.p2": "0x00000001",
 "ca.pv": "test:arg_echo"
Response:
 "ip.src": "192.168.11.237",
 "ip.dst": "10.1.1.1"
 "ca.size": "8",
 "ca.serv.port": "5064",
 "ca.serv.ip": "255.255.255.255",
 "ca.cid": "1",
 "ca.version": "0"
And so, the client tries to connect to the WiFi interface, while the IOC is only listening on the bridge. I don't understand why the IOC would respond from an address it is not listening on, and why this behavior is not consistent. Things start to work if I turn WiFi off. I tried keeping it on and just deleting the default route to see what happens, no change. Likewise, and as I'd expect, adding the WiFi address to EPICS_CAS_IGNORE_ADDR_LIST makes no difference. I hope someone here has an idea before I go dig into the code.
Jure Varlec
Senior Software Developer
Cosylab d.d.
www.cosylab.com
Re: Can't properly restrict IOC CA server to an interface Michael Davidsaver via Tech-talk
Prev: Re: Driver for Symetrie hexapods? Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Can't properly restrict IOC CA server to an interface Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Job opportunities at SNS/ORNL Vodopivec, Klemen via Tech-talk
