1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Dynamically changing HIHI PV field
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Apr 2022 17:49:37 +0000
Thanks, Torsten! It worked exactely as planned.
The only things i had to adjust were the scan fields: since my records are not asyn type, i changed the $(PREFIX)$(MOTOR_NAME)-CfgVELO-RB_ scan field to 1 second and the $(PREFIX)$(MOTOR_NAME)-CfgVELO-RB scan field to passive. So now the HIHI field of MY:VARIABLE is updated every 1 second.
Marco
Sent: 12 April 2022 13:46
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
I think that you need two helper records.
(this is a copy of our motor-business "as is", you need to adjust the macros and such)
One record that is "filled" by the hardware (driver), like below, which is an input record:
record(ai, "$(PREFIX)$(MOTOR_NAME)-CfgVELO-RB")
    field(DTYP, "asynFloat64")
    field(PREC, "$(PREC)")
    field(INP,  "@asyn($(MOTOR_PORT),$(AXIS_NO))CfgVELO-RB")
    field(SCAN, "I/O Intr")
The next helper record is an output record, that "pushes" it's value into the field
of the "wanted record", specified in the OUT field:
record(ao, "$(PREFIX)$(MOTOR_NAME)-CfgVELO-RB_")
    field(DOL,  "$(PREFIX)$(MOTOR_NAME)-CfgVELO-RB CP")
    field(OUT,  "$(PREFIX)$(MOTOR_NAME).VELO")
    field(OMSL, "closed_loop")
HTH
/Torsten
From: Tech-talk <[email protected]> on behalf of "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Reply-To: "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Tuesday, 12 April 2022 at 18:12
Subject: Dynamically changing HIHI PV field
Hello all.
I have an equipment which has the HIGH field configurable in the hardware. We already have a PV that reads it, but it is currently an entire PV, and not a field of another existing PV.
Im trying to get that PV result and put it in the HIGH field of another PV. Something like:
record(ai, "MY:PV") {
  field(HIHI, 10)
  field(HIGH, "ANOTHER:PV:HIGH:LIMIT PP")
  field(LOW, -1)
  field(LOLO, -5)
  field(HHSV, MAJOR)
  field(HSV, MINOR)
  field(LSV, MINOR)
  field(LLSV, MAJOR)
but each try of mine gets either syntax error or 'Can't set "MY:PV.HIGH" to "ANOTHER:PV:HIGH:LIMIT"'. Am i doing something wrong? Is this approach even possible?
Thanks in advance for any help.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Dynamically changing HIHI PV field Marco A. Barra Montevechi Filho via Tech-talk
Re: Dynamically changing HIHI PV field Torsten Bögershausen via Tech-talk
Prev: Re: Dynamically changing HIHI PV field Torsten Bögershausen via Tech-talk
Next: Re: Dynamically changing HIHI PV field Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
