1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: ADEiger R3-3 released
Date: Tue, 10 May 2022 17:37:19 +0000
Folks,
ADEiger R3-3 is now available.  This is from the release notes:
·         Fixed a problem with the Stream interface when stopping series acquisitions.
o    The problem was introduced in R3-1 when the ZMQ socket was no longer closed and re-opened for each acquisition.
o    When stopping an acquisition series the streamTask could exit before all messages had been read from the ZMQ socket.
o    When the next acquisition started it read stale messages from the socket. The only way to recover was to restart the IOC.
o    Now the streamTask does not exit when it detects that acquisition has been stopped. It relies on the fact that the Eiger server will always send an end frame when acquisition has been aborted.
o    This seems to work fine in testing Eiger 500K, and Eiger2 500K, 1M, and 9M.
o    If it proves not to be reliable there is commented out code in streamTask that will close and reopen the ZMQ socket and exit the thread when acquisition is aborted.
https://github.com/areaDetector/ADEiger
https://areadetector.github.io/master/ADEiger/eiger.html
Prev: Re: Device support of asyn port driver for system commands. Hu, Yong via Tech-talk
Next: Only cross compile option Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
