1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Can't create mutex semaphore: too many
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Luchini, Kristi L." <[email protected]>
Cc: Joel Sherrill <[email protected]>, Talk EPICS Tech <[email protected]>
Date: Tue, 11 Oct 2022 16:33:23 -0700
On 10/11/22 13:13, Luchini, Kristi L. wrote:
Hello,
Any news on a fix for this bug?
Not from me.
https://github.com/epics-base/pvAccessCPP/issues/184
Would removing PVA/QSRV from the binary solve the problem in this ioc for now?
It would.  You could also run "stopPVAServer" at the IOC shell
to stop the PVA server.  "startPVAServer" would then restart it
if desired.
A stop and restart should have the effect of clearing the beacon
tracking std::map which is causing this problem, although it will
also disconnect any PVA clients.
 This is an MPS Ioc and rebooting trips beam. So if I can find a temporary solution that would be great until we can get a bug fix.
MpsSupport_DBD += PVAServerRegister.dbd
MpsSupport_DBD += qsrv.dbd
MpsSupportSoft_LIBS += qsrv
USR_LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
-Kristi
-----Original Message-----
Sent: Thursday, May 26, 2022 2:57 PM
To: Michael Davidsaver <[email protected]>
Cc: Talk EPICS Tech <[email protected]>; Till Straumann <[email protected]>; Joel Sherrill <[email protected]>
Yes, I am using Till’s RTaeME configuration.
Kristi
Sent from my iPhone
On May 26, 2022, at 9:33 AM, Michael Davidsaver <[email protected]> wrote:
On 5/25/22 14:15, Michael Davidsaver wrote:
Indeed this appears to be the case.  There is an std::map used to
track which PVA servers have sent beacons.  Entries are added, but never removed.
Each entry has a Mutex (this code does very granular locking...).
I also notice that a temporary Mutex is allocated while processing
each search message.  Not a leak, but also not so efficient.
I've been playing around with "bpftrace" as an alternative to
"systemtap".  (imo. systemtap is great, but decoding its error
messages is no fun)
https://github.com/iovisor/bpftrace/blob/master/docs/reference_guide.m
d
$ cat rxmutex.bpf
// Print user stack trace when epicsMutexOsiCreate() called through
processBuffer() // unmangled name...
// epics::pvAccess::BlockingUDPTransport::processBuffer(
//  std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&,
//  osiSockAddr& fromAddress, ByteBuffer* receiveBuffer)
uprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-deb
ug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13pr
ocessBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvDat
a10ByteBufferE
    @inproc[tid] = 1;
uretprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-
debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport1
3processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pv
Data10ByteBufferE
    delete(@inproc[tid]);
uprobe:"/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/
libCom.so.3.21.1":epicsMutexOsiCreate
    if(@inproc[tid]) {
        printf("==============\n%s\n", ustack(perf));
Why yes, that c++ mangled symbol name is 127 characters long...
$ sudo bpftrace -p `pgrep softIocPVA` rxmutex.bpf Attaching 3
probes...
While running "pvget"
        7f474e0e2d53 epicsMutexOsiCreate+0 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
        7f474dbad4dc epics::pvAccess::ServerChannelFindRequesterImpl::ServerChannelFindRequesterImpl(std::shared_ptr<epics::pvAccess::ServerContextImpl> const&, std::shared_ptr<epics::pvAccess::PeerInfo const> const&, int)+308 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474dbaced7 epics::pvAccess::ServerSearchHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+1897 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474dbac094 epics::pvAccess::ServerResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+380 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db420b8 epics::pvAccess::BlockingUDPTransport::processBuffer(std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&, epics::pvData::ByteBuffer*)+736 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7fffffffe000 0x7fffffffe000 ([unknown])
        7f474e0e1869 epicsThreadCallEntryPoint+97 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
        7f474e0e9d96 start_routine+431 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
        7f474d764ea7 start_thread+215
(/usr/lib/x86_64-linux-gnu/libpthread-2.31.so)
While running another PVA server
        7f474db49e68 epics::pvAccess::BeaconHandler::BeaconHandler(std::shared_ptr<epics::pvAccess::Context> const&, osiSockAddr const*)+86 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db8c2cc (anonymous namespace)::InternalClientContextImpl::getBeaconHandler(osiSockAddr*)+244 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db83bfc (anonymous namespace)::BeaconResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+678 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db85b8d (anonymous namespace)::ClientResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+349 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
RE: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Prev: RE: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Next: Re: Tech-talk Digest, Vol 16, Issue 594 Carsten Winkler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: ADEiger R3-3 released Mark Rivers via Tech-talk
