1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Re: Can't create mutex semaphore: too many
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Talk EPICS Tech <tech-talk at aps.anl.gov>
Cc: "Luchini, Kristi L." <luchini at slac.stanford.edu>, Joel Sherrill <joel.sherrill at gmail.com>
Date: Thu, 26 May 2022 09:32:32 -0700
On 5/25/22 14:15, Michael Davidsaver wrote:
Indeed this appears to be the case.  There is an std::map used to track
which PVA servers have sent beacons.  Entries are added, but never removed.
Each entry has a Mutex (this code does very granular locking...).
I also notice that a temporary Mutex is allocated
while processing each search message.  Not a leak,
but also not so efficient.
I've been playing around with "bpftrace" as an
alternative to "systemtap".  (imo. systemtap is
great, but decoding its error messages is no fun)
https://github.com/iovisor/bpftrace/blob/master/docs/reference_guide.md
$ cat rxmutex.bpf
// Print user stack trace when epicsMutexOsiCreate() called through processBuffer()
// unmangled name...
// epics::pvAccess::BlockingUDPTransport::processBuffer(
//  std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&,
//  osiSockAddr& fromAddress, ByteBuffer* receiveBuffer)
uprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvData10ByteBufferE
    @inproc[tid] = 1;
uretprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvData10ByteBufferE
    delete(@inproc[tid]);
uprobe:"/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1":epicsMutexOsiCreate
    if(@inproc[tid]) {
        printf("==============\n%s\n", ustack(perf));
Why yes, that c++ mangled symbol name is 127 characters long...
$ sudo bpftrace -p `pgrep softIocPVA` rxmutex.bpf
Attaching 3 probes...
While running "pvget"
        7f474e0e2d53 epicsMutexOsiCreate+0 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
        7f474dbad4dc epics::pvAccess::ServerChannelFindRequesterImpl::ServerChannelFindRequesterImpl(std::shared_ptr<epics::pvAccess::ServerContextImpl> const&, std::shared_ptr<epics::pvAccess::PeerInfo const> const&, int)+308 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474dbaced7 epics::pvAccess::ServerSearchHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+1897 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474dbac094 epics::pvAccess::ServerResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+380 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db420b8 epics::pvAccess::BlockingUDPTransport::processBuffer(std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&, epics::pvData::ByteBuffer*)+736 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7fffffffe000 0x7fffffffe000 ([unknown])
        7f474e0e1869 epicsThreadCallEntryPoint+97 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
        7f474e0e9d96 start_routine+431 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
        7f474d764ea7 start_thread+215 (/usr/lib/x86_64-linux-gnu/libpthread-2.31.so)
While running another PVA server
        7f474db49e68 epics::pvAccess::BeaconHandler::BeaconHandler(std::shared_ptr<epics::pvAccess::Context> const&, osiSockAddr const*)+86 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db8c2cc (anonymous namespace)::InternalClientContextImpl::getBeaconHandler(osiSockAddr*)+244 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db83bfc (anonymous namespace)::BeaconResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+678 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
        7f474db85b8d (anonymous namespace)::ClientResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+349 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
RE: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Re: Can't create mutex semaphore: too many Joel Sherrill via Tech-talk
Re: Can't create mutex semaphore: too many Till Straumann via Tech-talk
Prev: Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Next: Scientific Software Positions at the Advanced Photon Source (APS) Schwarz, Nicholas via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Next: Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
