1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Issue or misunderstanding with long string support
Date: Tue, 31 May 2022 20:06:51 +0000
Our IOCs are now all running base 7.0.5.  We see an issue with medm screens containing string files using PVs that end in a “$”.  We can only change the first character in the string.
This is easy to reproduce using the caput and cainfo clients from base 7.0.5 to a PV in an IOC running base 7.0.5.
cainfo without the $ modifier shows the field is a DBF_STRING.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/cainfo 13BMD:userTran20.CLCA
    State:            connected
    Host:             ioc13bmd.cars.aps.anl.gov:5064
    Access:           read, write
    Native data type: DBF_STRING
    Request type:     DBR_STRING
    Element count:    1
cainfo with the $ modifier shows the field is a DBF_CHAR of size 120
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/cainfo 13BMD:userTran20.CLCA$
    State:            connected
    Access:           read, write
    Native data type: DBF_CHAR
    Request type:     DBR_CHAR
    Element count:    120
A caput without the $ modifier works, but that would be limited to 40 characters.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput 13BMD:userTran20.CLCA "A+B"
Old : 13BMD:userTran20.CLCA
New : 13BMD:userTran20.CLCA          A+B
A caput with the $ modifier does not work, only the first character in the string was changed.  It should have changed from A+B to B+A, but instead it changed to B+B.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput -S 13BMD:userTran20.CLCA$ "B+A"
Old : 13BMD:userTran20.CLCA$ A+B
New : 13BMD:userTran20.CLCA$ B+B
I see the same issue when writing to the DESC field of an ao record.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput testAo_1.DESC "123"
Old : testAo_1.DESC                  H23
New : testAo_1.DESC                  123
When writing with the $ modifier it should have changed “123” to “321”, but instead it is “323”.
corvette:local/epics-devel/base-7.0.6>/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64/caput -S testAo_1.DESC$ "321"
Old : testAo_1.DESC$ 123
New : testAo_1.DESC$ 323
Is this a bug, or am I misunderstanding how long strings are supposed to work?
This looks similar to this bug that is fixed in 7.0.6.1, but that says it was specific to the CALC field.  https://github.com/epics-base/epics-base/issues/194
RE: Issue or misunderstanding with long string support Mark Rivers via Tech-talk
Prev: A module for LabMax laser power/energy meter (Coherent) Jong Woo Kim via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: RE: Issue or misunderstanding with long string support Mark Rivers via Tech-talk
