1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: AW: Alarm-Server within a container
From: "Gotz, Malte via Tech-talk" <[email protected]>
To: "Larregui, Julian" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Jun 2022 11:22:59 +0000
Hi Julian,
I think you are right, your problem lies probably in the settings you mentioned. Advertising kafka as localhost, will only work if you are running everything from within the same container or maybe have both kafka and zookeeper on the same container and run the create topic from the host machine. I found a lot of setups for kafka inside docker use two listeners: One for inside the docker network for inter broker communication + zookeeper, and one bound to your host to communicate to the outside.
I found settings this up quite painful. Now, I have a docker compose that has been working well for me. It uses the wurstmeister kafka and zookeeper images. I disentangled it from the rest of my mess and put it here: https://gitlab.helmholtz-berlin.de/a2324/phoebus-alarm-docker. Maybe it is helpful to you or you might even use it as it. If you have any problems with that, I am happy to help.
Malte
Von: Tech-talk <[email protected]> Im Auftrag von Larregui, Julian via Tech-talk
Gesendet: Mittwoch, 1. Juni 2022 20:20
An: [email protected]
Betreff: Alarm-Server within a container
Hello,
As the subject says I'm trying to get the alarm-server working with phoebus.
I've already built the image and created the container. I can run zookeeper-server-start and kafka-server-start just fine.
The issue becomes when trying to create a topic. Usually it is met with this error:
Error while executing topic command : Timed out waiting for a node assignment. Call: createTopics
[2022-06-01 17:51:09,207] ERROR org.apache.kafka.common.errors.TimeoutException: Timed out waiting for a node assignment. Call: createTopics
 (kafka.admin.TopicCommand$)
My assumption is incorrectly setting up the server.properties file, but unsure what to set it at.
currently:
listeners=PLAINTEXT://localhost:9092
advertised.listeners=PLAINTEXT://localhost:9092
zookeeper.connect=localhost:2181
Any advice would be welcomed.
Thank you for your time,
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Alarm-Server within a container Larregui, Julian via Tech-talk
Prev: Monitoring sscan record fields. [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Next: stream feature which similar wireshark 网易邮件中心 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Alarm-Server within a container Jörn Dreyer via Tech-talk
Next: Strange memory leak with ADAravis Abdalla Ahmad via Tech-talk
