1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: win10 and base7.0.6.1
From: Matt Clarke via Tech-talk <[email protected]>
To: 网易邮件中心 <[email protected]>
Date: Tue, 14 Jun 2022 12:35:58 +0000
To follow up on what Mark said: you say you are using VS2022 but you are using the path to VS2019, i.e.
set _visual_studio_home=D:\Program Files\VS2019\
That might explain why it cannot find cl.exe.
Cheers,
Matt
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Reply-To: Mark Rivers <[email protected]>
Date: Tuesday, 14 June 2022 at 13:58
Subject: RE: win10 and base7.0.6.1
It sounds like perhaps cl.exe is not in your path.  At the same Windows command prompt that generated the error you showed what do you see if you type this command:
cl
I see this when I build with VS 2015.
H:\epics-devel\base-7.0.6.1>cl
Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
From: Tech-talk <[email protected]> On Behalf Of ?????? via Tech-talk
Sent: Tuesday, June 14, 2022 3:01 AM
To: tech-talk <[email protected]>
Subject: win10 and base7.0.6.1
     I was try to use epics on Win1064.
base 7.0.6.1
Strawberry Perl (64-bit) 5.32.1.1-64bit
Win10 family    Microsoft Windows [Version 10.0.19044.1706]
Visual Studio 2022
set _epics_host_arch=windows-x64
windows.bat
set _auto=yes
set _auto_path_reset=%_auto%
set _auto_path_append=%_auto%
set _path_new=C:\Windows\System32;C:\Windows;C:\Windows\System32\wbem
set _strawberry_perl_home=C:\Strawberry
set _epics_base=D:\epics\base-7.0.6.1
set "PATH=%PATH%;%_strawberry_perl_home%\c\bin"
set "PATH=%PATH%;%_strawberry_perl_home%\perl\site\bin"
set "PATH=%PATH%;%_strawberry_perl_home%\perl\bin"
call "%_visual_studio_home%\VC\Auxiliary\Build\vcvarsall.bat" x64
Output of gmake after windows.bat and gmake:
gmake[3]: Entering directory 'D:/epics/base-7.0.6.1/modules/libcom/src'
C:/Strawberry/c/bin/gmake -C O.windows-x64 -f ../Makefile TOP=../../../.. \
    T_A=windows-x64 install
gmake[4]: Entering directory 'D:/epics/base-7.0.6.1/modules/libcom/src/O.windows-x64'
"Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h"
perl -CSD D:/epics/base-7.0.6.1/bin/windows-x64/expandVars.pl -t ../../../.. -D INSTALL_BIN=D:/epics/base-7.0.6.1/bin/windows-x64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="0"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="0"  ../libComVersion.h@ libComVersion.h
"Installing generated generic include file ../../../../include/libComVersion.h"
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../flex/ccl.c
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../flex/ccl.c, ...) failed.
make (e=2): System could not find the file.
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../yacc/closure.c
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../yacc/closure.c, ...) failed.
gmake[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
gmake[4]: Leaving directory 'D:/epics/base-7.0.6.1/modules/libcom/src/O.windows-x64'
gmake[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
gmake[3]: Leaving directory 'D:/epics/base-7.0.6.1/modules/libcom/src'
gmake[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
gmake[2]: Leaving directory 'D:/epics/base-7.0.6.1/modules/libcom'
gmake[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
gmake[1]: Leaving directory 'D:/epics/base-7.0.6.1/modules'
gmake: *** [configure/RULES_DIRS:85: modules.install] Error 2
Liang
win10 and base7.0.6.1 网易邮件中心 via Tech-talk
RE: win10 and base7.0.6.1 Mark Rivers via Tech-talk
Prev: RE: win10 and base7.0.6.1 Mark Rivers via Tech-talk
Next: Re: win10 and base7.0.6.1 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
