The information that you have both given me has helped get me over the hurdle of configuration and progress has been made.
I now have a Kafka server with a new alarm topic (along with the original Accelerator topic).
I have modified the Kafka server.properties to use the host LAN interface (rather than localhost loop-back).
The Alarm server is now started with the '-server <host>:9092' switch
Phoebus on the Windows client now has a settings.ini file, which includes the line: "org.phoebus.applications.alarm/server=<host>:9092"
Now Phoebus runs on the Windows workstation and sees the alarm server and all available topics.
Many thanks both Kay and Malte for your helpful advice.
Ian
-----Original Message----- Subject: Re: Phoebus connection to alarm server / Kafka Date: Tue, 28 Jun 2022 12:22:19 +0000
Note that you can share the same Kafka server for multiple alarm setups. Depending on your overall infrastructure, you can decide to either have one central kafka setup, so all the alarm tools (server, GUI) point to that one:
org.phoebus.applications.alarm/server=the_one_kafka_server.mysite.org:9092
On that server, you create the alarm topics for say "Accelerator", "Cryo", "Facilities".
For the GUI, you have two options. You can either do this:
# Start with "Accelerator" as the default for newly opened Alarm Table and Alarm Tree:
org.phoebus.applications.alarm/config_name=Accelerator # .. but allow selecting any of the three setups via a drop-down on the alarm table & tree:
org.phoebus.applications.alarm/config_names=Accelerator, Cryo, Facilities
Or you do this:
# Start with "Accelerator" as the default for newly opened Alarm Table and Alarm Tree:org.phoebus.applications.alarm/config_name=Accelerator # .. and don't allow changing that:
So possible options include: a) Run one Kafka server for your site, which may be shared with other tools that use Kafka b) Run one Kafka server per alarm setup, and use it only for that. Kinda like running MySQL or Oracle, where you typically share it with a variety of applications, but you can also run an instance just for one app.
You _always_ need to run one alarm server per configuration.
On the GUI side, you can then decide to a) Allow access to multiple alarm setups, operators can select at runtime b) Lock the CS-Studio GUI for the main control room to "Accelerator", the one for the cryo control room to "Cryo" etc.
-Kay
From: Tech-talk on behalf of Gotz, Malte via Tech-talk
this: https://control-system-studio.readthedocs.io/en/latest/preference_properties.html#preference-settings is an overview of all the preferences available for Phoebus, I like to use as a reference. Luckily, alarm is at the very top. You need to preface the property with the package. So, create a settings file with: org.phoebus.applications.alarm/server=your.host.com:9092
org.phoebus.applications.alarm/config_name=YourTopic org.phoebus.applications.alarm/config_names=YourTopic, YourOtherTopic and pass it to Phoebus with -settings your-settings.ini I now need to modify it for my own requirements and have used the phoebus/app/alarm/examples/create_alarm_topics.sh script to create a new topic. I will have Phoebus clients running on Windows machines (on the same network). Is someone able to point me at the documentation as to where to edit Phoebus configuration to tell it which host:port to connect to for the alarm server (running on a single Linux box) and to change the Kafka topic?
