1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: StreamDevice return state error
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "Zimoch Dirk (PSI)" <[email protected]>
Date: Wed, 29 Jun 2022 12:24:01 +0000
Hi:
> > > The error "Record does not accept input" happens when you send a string (parsed with %s) to a record with an enum
> > > VAL
> > > like your mbbi, but the string does not match any of the enum strings in the record.
> > > As your record only has "STANDBY", "OPERATE" and "SELFTEST", it does not accept the input "MONITOR".
> > The mbbi should be in INVALID/CALC alarm state after that.
> Except.... that your record is "I/O Intr". Such records get all the available input but process only matching input.
> Non-matching input is silently ignored. That is by design how StreamDevice implements I/O Intr.
That all makes sense.
SCAN=I/O Intr checks everything but only reacts on match.
Anything else is assumed to be meant for some other record and thus ignored.
Maybe the issue could be avoided by changing the message from
  error .. does not accept input 'MONITOR'
to something like
   info .. value 'MONITOR' ignored because outside of expected values.
Cheers,
Kay
Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
StreamDevice return state error Barrett (US), Patrick E via Tech-talk
Prev: Re: Phoebus connection to alarm server / Kafka Ian Gillingham via Tech-talk
Next: Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
