Is there a suggested version of asyn I can use if I’m not using base 7 but the latest base 3.15?
I see in the latest releases that a lot of the overloads for are using richer type ints that are only served by base 7.
e.g. FtypeUINT64
https://epics.anl.gov/base/R3-15/9-docs/menuFtype.html vs https://epics.anl.gov/base/R7-0/6-docs/menuFtype.html
Kind Regards
Tim Speight
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- RE: Lowest compatible version of asyn for base 3-15.9 Mark Rivers via Tech-talk
Re: Issue with Asyn+StreamDevice on a Raspi CM4 Florian Feldbauer via Tech-talk
RE: EPICS compilation errors Mark Rivers via Tech-talk
<2022>
2025
2026
Re: Teledyne Dalsa Areadetector Driver (David Vine) David Vine via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
