1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: EPICS compilation errors
To: Andrew Johnson <[email protected]>, Adrian Martinez <[email protected]>
Date: Tue, 12 Jul 2022 16:02:25 +0000
Ø  This description implies that some iocsh callable routine probably needs to make a strcpy() of its parameter name string argument, or to change it from iocshArgString to iocshArgPersistentString in the iocshArg definition (which does that for you).
I don’t think that is likely to be the problem for 2 reasons:
-          I don’t think these parameter names are passed via iocsh callable functions, they are hardcoded in the driver.
-          asynPortDriver::createParam(const char *name, asynParamType type, int *index) passes the pointer to the parameter name to one of these paramVal constructors
paramVal::paramVal(const char *name):
    type(asynParamNotDefined), status_(asynSuccess), alarmStatus_(0), alarmSeverity_(0),
    valueDefined(false), valueChanged(false)
    this->name = epicsStrDup(name);
paramVal::paramVal(const char *name, asynParamType type):
    type(type), status_(asynSuccess), alarmStatus_(0), alarmSeverity_(0),
    valueDefined(false), valueChanged(false){
    memset(&this->data, 0, sizeof(this->data));
Note that both of these copy the name to the paramVal object using epicsStrDup, so they do not assume a persistent pointer.
Sent: Tuesday, July 12, 2022 10:17 AM
To: Mark Rivers <[email protected]>; Adrian Martinez <[email protected]>
Subject: Re: EPICS compilation errors
On 7/12/22 7:24 AM, Mark Rivers via Tech-talk wrote:
Hi Adrian,
Your parameter library looks fine before iocInit, but after iocInit all of the parameter names have changed to either an empty string "", or "BPM1".
Does your driver implement the drvUserCreate() method?  If so, that gets called during iocInit and perhaps you have an error in that method.  The names of the parameters should not be changing after they are created.
The only parameter whose name has not changed after iocInit is this one:
Parameter 28 type=asynInt32, name=enable_compensation, value=0, status=0
Perhaps that is a clue?
- Andrew
Complexity comes for free, Simplicity you have to work for.
EPICS compilation errors Adrian Martinez via Tech-talk
RE: EPICS compilation errors Mark Rivers via Tech-talk
RE: EPICS compilation errors Adrian Martinez via Tech-talk
Re: EPICS compilation errors Mark Rivers via Tech-talk
Re: EPICS compilation errors Andrew Johnson via Tech-talk
Prev: Lowest compatible version of asyn for base 3-15.9 Timothy Speight - STFC UKRI via Tech-talk
Next: RE: Lowest compatible version of asyn for base 3-15.9 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS compilation errors Andrew Johnson via Tech-talk
Next: EPICS-Support for Owis motor stages Sintschuk, Michael via Tech-talk
