1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Lowest compatible version of asyn for base 3-15.9
To: Timothy Speight - STFC UKRI <[email protected]>
Date: Tue, 12 Jul 2022 16:51:15 +0000
Hi Tim,
The lastest versions of asyn should still work fine with older versions of base.  I have tried to maintain backwards compatibility with old versions of base.  This is discussed in the release notes for versions R4-37 and R4-38.
https://epics-modules.github.io/master/asyn/R4-42/RELEASE_NOTES.html
I just tested that the latest master branch of asyn builds fine with base 3.15.5.
Are you having problems building or using the latest version of asyn with base 3.15?
From: Tech-talk <[email protected]> On Behalf Of Timothy Speight - STFC UKRI via Tech-talk
Sent: Tuesday, July 12, 2022 11:02 AM
To: '[email protected]' <[email protected]>
Subject: Lowest compatible version of asyn for base 3-15.9
Is there a suggested version of asyn I can use if I’m not using base 7 but the latest base 3.15?
I see in the latest releases that a lot of the overloads for are using richer type ints that are only served by base 7.
e.g. FtypeUINT64
https://epics.anl.gov/base/R3-15/9-docs/menuFtype.html vs https://epics.anl.gov/base/R7-0/6-docs/menuFtype.html
Kind Regards
Tim Speight
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Lowest compatible version of asyn for base 3-15.9 Timothy Speight - STFC UKRI via Tech-talk
Prev: RE: EPICS compilation errors Mark Rivers via Tech-talk
Next: A way to ensure that a record chain completes processing before processing another record chain Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Lowest compatible version of asyn for base 3-15.9 Timothy Speight - STFC UKRI via Tech-talk
