Disabling the scan threads cannot be done without modifying
epics-base. Running the hook at a different point (e.g. at
initHookAfterStopScan) won't help, the threads are/never/ stopped.
Best,
Jure
*From:* Tech-talk <[email protected]> on behalf of Érico
Nogueira Rolim via Tech-talk <[email protected]>
*Sent:* Wednesday, July 20, 2022 16:18
*To:* Michael Davidsaver <[email protected]>; Mark Rivers
<[email protected]>; Andrew Johnson <[email protected]>
*Cc:* tech-talk <[email protected]>
*Subject:* Re: How to safely implement an asynPortDriver with SCAN
records
Caution: This email originated from outside of Cosylab.
On 08/07/2022 17:37, Michael Davidsaver wrote:
On 7/8/22 11:11, Mark Rivers via Tech-talk wrote:
Hi Andrew,
To be honest I have not paid enough attention to how to correctly
handle destructors in asynPortDriver.
On the occasions when I've used asynPortDriver, I put a cantProceed()
in the sub-class destructor.
Can you say where exactly in the destructor you used cantProceed()? I
can't seem to make it behave correctly: the IOC never exits, though it
does dump a stack trace.
After a call to registerInterface(), the asynInterface::drvPvt pointer
must remain valid until
the process exits. So an asyn port can't be destroyed.
I've toyed with the ideas like re-counter asynUser, or somehow later
setting drvPvt=NULL.
Both seem possible, but not without quite some effort.
This situation is made more complicated by the fact that IOC scan
threads are not stopped on exit.
We do now stop them during database unit tests. However, some ~vague
compatibility concerns have
so far kept this from being done for full IOCs.
Where does this choice happen? Could one do it for their own IOC?
Personally, as a matter of good practice, drivers I write always
include an epicsAtExit() handler
which stops any worker threads.
Also, I should mention the de-init hooks added in Base 7.0.4 to
decouple database shutdown from
process exit.
https://github.com/epics-base/epics-base/commit/5d5e552a7ec6ef69459c97b0081aa775372a6290#diff-02e4602d43dbb03b4097bb26382a1db92367fb55fe791415cd32d4f234875d92R50
<https://github.com/epics-base/epics-base/commit/5d5e552a7ec6ef69459c97b0081aa775372a6290#diff-02e4602d43dbb03b4097bb26382a1db92367fb55fe791415cd32d4f234875d92R50>
For compatibility, the effect of initHookAtShutdown can mostly be
replicated by calling epicsAtExit()
at initHookAfterIocRunning.
If I understand correctly, what I'd want for my own code would be
calling the driver's destructor in initHookAfterStopScan? If it ran for
full IOCs, of course.
Aviso Legal: Esta mensagem e seus anexos podem conter informações
confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo
e considere eventual consulta ao remetente antes de copiá-la,
divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano,
por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential
and/or privileged information. Observe its content carefully and
consider possible querying to the sender before copying, disclosing
or distributing it. If you have received this email by mistake,
please notify the sender and delete it immediately.
