Hi Andy,
On 7/26/22 6:53 PM, Wang, Andrew via
Tech-talk wrote:
Update. I think I got it. I had to do the following.
static
long func(aSubRecord *prec)
DBLINK inpa = prec->inpa;
char *rec_name = inpa.value.pv_link.pvname;
printf("Record name in INPA is %s\n", rec_name);
return 0;
A DBLINK is a
structure (not a pointer) so your first line of code is copying data
that you don't need to do, and the value.pvlink union member is only valid
for certain kinds of link, so I would suggest something like this,
which adds protection from that by only showing DB and CA links:
static long
DBLINK *plink = &prec->inpa;
if (plink->type == DB_LINK || plink->type == CA_LINK) {
const char *target = plink->value.pv_link.pvname;
printf("Record %s.INPA links to %s\n", prec->name, target);
return 0;
HTH,
- Andrew
Andrew
Sent: Tuesday, July 26, 2022 4:17 PM
To: EPICS tech-talk <[email protected]>
Subject: Retrieving record name from aSub input/output
fields
Hi all,
Quick question this time. I was
wondering if there was a way to retrieve the name of the
record referenced in an OUTLINK/INLINK field such as INPA,
OUTA, etc. in the aSub routine.
For instance, suppose I had an aSub
record such as the following.
record(aSub, “example”)
field(SNAM, “func”)
field(INPA,
“rec_in_inpa”)
I would like to be able to print the
name of the record in INPA within “func”.
static long func(aSubRecord *prec)
char *rec_name =
prec->____;
printf(“Record name in
INPA is %s\n”, rec_name);
return 0;
Andy
Purple ribbon awareness
Complexity comes for free, Simplicity you have to work for.
- Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
- Re: Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
<2022>
2025
2026
PVA and Docker on Mac Juan F. Esteban Müller via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
